D-Link Wireless AC1200 Wave2 Dual Band Indoor PoE Access Point
Quicklinx: J7JJWS00 Mfr#: DAP-2662
Hurry, only 2 left in stock!
£134.94 ex VAT
£161.92 inc VAT
The D-Link DAP-2662 wireless access point is designed to meet the needs of modern businesses and tech-savvy homes. With support for Wi-Fi 5 and dual-band connectivity, users can enjoy high-speed Internet access across both 2.4 GHz and 5 GHz bands, ensuring optimal performance for a wide range of devices. Security is a priority, with the DAP-2662 offering a comprehensive suite of encryption protocols including AES, WPA, and WPA2-Enterprise to protect your network from unauthorized access.
Power over Ethernet (PoE) technology allows for flexible installation options, reducing the need for additional power cables and simplifying the setup process. Additionally, the device's capability to support up to 16 SSIDs makes it an ideal choice for organizations requiring multiple networks. With features such as 2x2 MIMO technology and comprehensive remote management protocols, the DAP-2662 is a versatile and effective solution for enhancing your network's performance and security.
  • Enhanced connectivity
    With dual-band support for both 2.4 GHz and 5 GHz frequencies, the DAP-2662 offers versatile wireless solutions. The inclusion of Wi-Fi 5 technology ensures a faster and more reliable connection for all your devices.
  • Robust security
    Equipped with multiple encryption algorithms including AES, WPA, WPA2, and WPA2-Enterprise, the DAP-2662 provides a secure networking environment. This comprehensive security suite protects against unauthorized access and ensures your network's integrity.
  • Efficient management
    The DAP-2662 supports various remote management protocols such as SNMP, HTTP, and SSH, allowing for easy and efficient configuration and management of your network infrastructure.
  • Advanced features
    Features like 2x2 MIMO technology, bridge mode, and support for up to 16 SSIDs make this wireless access point a powerful tool for enhancing network performance and flexibility.
  • Power over Ethernet
    PoE support eliminates the need for a separate power supply, enabling flexible installation options and reducing clutter. This feature simplifies the deployment of network devices in various environments.
D-Link DAP-2662 - radio access point - Wi-Fi 5
Radio access point
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 1
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
Power Over Ethernet (PoE) Supported
PoE
Radio access point
External
Wireless
Network / Transport Protocol
ARP, IPv6
Routing Protocol
IGMP, STP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
IGMP snooping, Syslog support, MAC address filtering, Wireless Distribution System (WDS) support, SNTP support, DHCP server, Unscheduled Automatic Power Save Delivery (U-APSD), ARP spoofing, bridge mode, 2x2 MIMO technology, HotSpot 2.0, WMM Power Save
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA2-Enterprise, WEP
IEEE 802.1D, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 1
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45
PoE
Brand: D-Link
