D-Link Wireless AC 1300 Wave2 Dual-Band Unified Access Point
Quicklinx: DQGYWS00 Mfr#: DWL-6620APS
  • IEEE 802.11n
£331.83 ex VAT
£398.19 inc VAT
The DWL-6620APS wireless access point is designed for small to medium businesses and enterprises, providing greater throughput and flexibility for medium to large-scale Wi-Fi networks. Featuring D-Link technology, the DWL6620APS allows your wireless clients to enjoy an incredible Wi-Fi experience and reliable connection.
  • Greater speed and connectivity
    The DWL-6620APS provides unparalleled connectivity, allowing high combined data rates over the air. Wireless clients can stream media faster and smoother than before using existing devices.
  • Performance upgrade
    The DWL-6620APS features an upgraded CPU, providing increased performance. Superior technology enables the DWL-6620APS to intelligently place clients on the optimal wireless band to avoid congestion and allows for smooth streaming of video, seamless browsing, and fast downloads for mobile devices.
D-Link DWL-6620APS - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
AC 120/230 V
22 cm x 22 cm x 5.545 cm
614 g
Radio access point
22 cm
22 cm
5.545 cm
614 g
External
Wireless
Data Transfer Rate
1267 Mbps
Remote Management Protocol
Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Power over Ethernet (PoE), VLAN support, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, ceiling mountable, 2x2 MU-MIMO technology
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Directivity
Omni-directional
2 x 1000Base-T (PoE) - RJ-45 , 1 x console - RJ-45
MTBF
925,606 hours
BSMI, EN 61000-3-2, EN 61000-3-3, EN55024, IC, UL 2043, FCC, EN 60601-1-2, LVD, NCC, RCM, EN 55032, EN 300328, EN 301893, cUL+UL, EN 301489-1, EN 301489-17
External power adapter
AC 120/230 V
16.32 Watt
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1267Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Brand: D-Link
