The mydlink Wi-Fi smart plug is a versatile and easy-to-use device that allows you to control an electrical appliance from your smartphone or tablet, wherever you are. You can set automatic schedules to turn on or off appliances such as lamps and heaters at specific times and days of the week.
Control your appliance from anywhere
With the Wi-Fi smart plug, you can control the attached electrical appliance in your home while you're away. Set a schedule that turns on the heater in those cold winter evenings, power on your coffee maker in the morning before you wake up, or automatically turn on your living room lamp while you're on holiday. Forgotten to turn off the iron after you've left the house, no need to panic, turn it off remotely from with a few taps on your smartphone. -
Compact design
The Wi-Fi smart plug is designed to fit discreetly into any home. The visual light ring around the device lets you quickly see the whether it's on or off. It also works as a night light to guide you when it's dark. In case it becomes bothersome, you also have the option to turn it off at any time at the press of a button.
- mydlink - smart plug
- Product Type
- Smart plug
- Functions
- Turn electronics on/off
- Intelligent Assistant
- Google Assistant, Alexa
- Connectivity
- Wireless - 802.11n
- Supported Host Device OS
- iOS, Android
- 7.4 cm x 3.8 cm x 9.5 cm
- Product Type
- Smart plug
- Functions
- Connectivity Technology
- Wireless - IEEE 802.11n
- iOS, Android
- Push notification, power scheduling, remote access, LED indicator Wi-Fi Protected Setup (WPS)
Internet of Things (IoT)
- Compatible Services
- IFTTT
Aerial
- Form Factor
- Internal
- Quantity
- 1
- Encryption Algorithm
- WPA, WPA2, WEP
- RoHS, LVD, ERP
- 7.4 cm
- 3.8 cm
- 9.5 cm
- 155 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
