D-Link Vigilance HD Wireless Camera
Quicklinx: B8FQWS00 Mfr#: DCS-4201
  • microSDHC Card
  • microSD Card
The Vigilance Wireless HD Camera is a professional, full featured HD camera that is easy to install and highly affordable. Capable of viewing up to 10 metres at night thanks to its infrared LED illuminator, this camera can monitor an area even in complete darkness.
A built-in microphone and speaker allows for 2-way communication, which is ideal for use in entryways or for caretaker applications. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send a notification when motion is detected.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
Security Installer Focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
  • Versatile connectivity
    With both wired and wireless connectivity options, including Ethernet 10Base-T/100Base-TX and IEEE 802.11b/g/n Wi-Fi, this network surveillance camera ensures flexible installation and easy integration into your existing network infrastructure.
  • Enhanced night vision
    Equipped with infrared LEDs and capable of capturing clear footage up to 10 m away in complete darkness, the camera provides reliable surveillance around the clock. Its day and night functionality, coupled with a sensitive CMOS sensor, ensures high-quality video capture in both color and B&W modes.
  • High-quality audio and video
    Featuring a built-in microphone and speaker with two-way audio capability, this camera allows for easy communication with visitors or intruders. It supports digital video capture resolutions up to 1280 x 720, ensuring crisp, clear images. The inclusion of 3D Noise Reduction Technology and a frame rate of up to 30 frames per second further enhances video quality.
  • Smart surveillance features
    With motion detection, event notification, and ONVIF support, this camera is equipped to handle a variety of security scenarios. Users can customize settings to receive alerts for specific events, making it easier to monitor and respond to incidents as they occur.
D-Link DCS-4201 - network surveillance camera
Network surveillance camera - fixed
Audio
Built-in speaker, two-way audio capability, built-in microphone
5.8 cm x 3.07 cm x 9.5 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
Motion Detection
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux - colour - F2.4 , 0.5 lux - B&W - F2.4 , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
1.8 mm
Lens Iris
F/2.4
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
IR filter, e-mail alerts, ONVIF support, 3D Noise Reduction Technology, Motion Detection Technology, Event Notification
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
5.8 cm
3.07 cm
9.5 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Digital Zoom
4
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
1280 x 720, 960 x 720
Frame Rate (max)
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
1.8 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
97.6
Vertical Field of View (degree)
69.2
Network Interface
Network Protocols
IPv6
Supported Memory Cards
microSD Card, microSDHC Card
C-Tick, FCC, LVD
Relative Humidity (operating)
B8FQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B8FQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.84
