Product
D-Link Vigilance HD Outdoor PoE Mini Bullet Camera
Quicklinx: B8FTWS00 Mfr#: DCS-4701E
Hurry, only 3 left in stock!
£130.95 ex VAT
£157.14 inc VAT
The Vigilance HD Outdoor PoE Mini Bullet Camera is a professional, full featured HD camera with LowLight+ support, to see in in color, even in extremely low light conditions. Integrate IR illuminator allows the camera to see up to 30 meters in complete darkness whilst IP66 (weather-proof) housing is specifically designed to withstand adverse weather conditions.
  • Vigilance range
    The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
  • Security installer focused
    Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
D-Link DCS-4701E HD Outdoor PoE Mini Bullet Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - vandal-proof
6.5 cm x 6.5 cm x 16.4 cm
635 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.2 lux - colour - F2.0 , 0.1 lux - B&W - F2.0 , 0 lux - IR
Focal Length
2.8 mm
Lens Iris
F/1.8
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V
Motion sensor, Power over Ethernet, e-mail alerts, Wide Dynamic Range (WDR), 3D Noise Reduction Technology, Open Network Video Interface Forum (ONVIF), Privacy Mask Function, NAS-Ready
Environmental Parameters (operating)
-30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Wired
6.5 cm
6.5 cm
16.4 cm
635 g
Camera
Colour - Day&Night - fixed - outdoor - vandal-proof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Digital Zoom
10
Infrared LEDs
Video Capture
1280 x 720 @ 30 fps
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Focal Length
2.8 mm
Lens Iris
F/1.8
Horizontal Field of View (degree)
96
Vertical Field of View (degree)
54
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, QOS, 3GPP/ISMA, CoS
FCC Class A certified, C-Tick, IK10, IP66, LVD
Power Requirements
DC 12 V
Power adapter - external AC 100/230 V (50/60 Hz)
-30 °C
50 °C
Relative Humidity (operating)
B8FT C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
B8FT C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
B8FT C2G 2m Cat6a Shielded Patch - Blue In Stock £7.04
Brand: D-Link
Price Range Ex VAT: 100 - 150
