The Vigilance HD Outdoor PoE Mini Bullet Camera is a professional, full featured HD camera with LowLight+ support, to see in in color, even in extremely low light conditions. Integrate IR illuminator allows the camera to see up to 30 meters in complete darkness whilst IP66 (weather-proof) housing is specifically designed to withstand adverse weather conditions.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments. -
Security installer focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
- D-Link DCS-4701E HD Outdoor PoE Mini Bullet Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - vandal-proof
- 6.5 cm x 6.5 cm x 16.4 cm
- 635 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/3" - 1.3 MP
- Minimum Illumination
- 0.2 lux - colour - F2.0 , 0.1 lux - B&W - F2.0 , 0 lux - IR
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V
- Motion sensor, Power over Ethernet, e-mail alerts, Wide Dynamic Range (WDR), 3D Noise Reduction Technology, Open Network Video Interface Forum (ONVIF), Privacy Mask Function, NAS-Ready
- Environmental Parameters (operating)
- -30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Wired
- 6.5 cm
- 6.5 cm
- 16.4 cm
- 635 g
Camera
- Colour - Day&Night - fixed - outdoor - vandal-proof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Video Modes
- 720p
- Digital Zoom
- 10
- Infrared LEDs
- Video Capture
- 1280 x 720 @ 30 fps
Image Sensor
- 1.3 MP CMOS 1/3"
Lens Construction
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Horizontal Field of View (degree)
- 96
- Vertical Field of View (degree)
- 54
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, QOS, 3GPP/ISMA, CoS
- FCC Class A certified, C-Tick, IK10, IP66, LVD
- Power Requirements
- DC 12 V
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.65 |
