D-Link Vigilance Full HD Outdoor PoE Mini D Camera
Quicklinx: B8FVWS00 Mfr#: DCS-4802E
Hurry, only 2 left in stock!
£160.33 ex VAT
£192.39 inc VAT
The Vigilance Full HD Outdoor PoE Mini Dome Camera is a professional, full featured full HD Camera with IP-66 (weather-proof) housing, specifically designed to withstand adverse weather conditions. Incorporating IR LED illuminator, WDR and 3DNR support, you get up to 30 meters night vision and clear detailed images in contrasting and low light environments.
  • Vigilance range
    The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
  • Security installer focused
    Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
D-Link Vigilance DCS-4802E Full HD Outdoor PoE Mini Dome Camera - network surveillance camera
Network surveillance camera - pan / tilt - outdoor - vandal-proof
11.3 cm x 11.3 cm x 7.77 cm
635 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 2 MP
Minimum Illumination
1 lux - colour - F2.0 , 0.5 lux - B&W - F2.0 , 0 lux - IR
Focal Length
2.8 mm
Lens Iris
F/1.8
Panning Range (degree)
350
Tilting Range (degree)
60
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V
Motion sensor, Power over Ethernet, e-mail alerts, Wide Dynamic Range (WDR), 3D Noise Reduction Technology, Open Network Video Interface Forum (ONVIF), NAS-Ready
Environmental Parameters (operating)
-30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Wired
11.3 cm
11.3 cm
7.77 cm
635 g
Camera
Colour - Day&Night - pan / tilt - outdoor - vandal-proof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Digital Zoom
10
Infrared LEDs
Video Capture
1920 x 1080 @ 30 fps
Image Sensor
2 MP CMOS 1/3"
Lens Construction
Focal Length
2.8 mm
Lens Iris
F/1.8
Horizontal Field of View (degree)
96
Vertical Field of View (degree)
54
Panning
Range (degree)
350
Titling
Range (degree)
60
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, QOS, 3GPP/ISMA, CoS
FCC Class A certified, C-Tick, IK10, LVD
Power Requirements
DC 12 V
No power supply
-30 °C
50 °C
Relative Humidity (operating)
B8FV C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
B8FV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
B8FV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.36
B8FV C2G 2m Cat6a Shielded Patch - Blue In Stock £7.62
Brand: D-Link
Price Range Ex VAT: 150 - 300
