D-Link Vigilance Full HD 360 PoE Dome Camera
Quicklinx: CQGMWS00 Mfr#: DCS-4622
  • microSD Card
£142.22 ex VAT
£170.66 inc VAT
DCS-4622 is a Full HD 360° network camera as an entry type for video surveillance and security. This camera adopts 3MP progressive scan CMOS sensor. The camera is designed for both indoor and day/night applications, thus, the camera built-in removable IR-cut filter and IR LED, which can support long distance. The DCS-4622 has a built-in 802.3af compliant PoE module, that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling.
D-Link DCS 4622 - network surveillance camera - dome
Network surveillance camera - fixed - dome
Audio
Yes: built-in speaker, built-in microphone
9.7 cm x 9.7 cm x 4.83 cm
210 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1536
Frame Rate (max)
25 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 3 MP
Minimum Illumination
0.5 lux - colour , 0.25 lux - B&W , 0 lux - IR
Focal Length
1.1 mm
Focus Adjustment
(min distance 30 cm)
Lens Iris
F/2.0
Tilting Range (degree)
15
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Sharpness control, saturation control, brightness control, contrast control, Wide Dynamic Range (WDR), built-in IR illuminator, exposure control, ICR filter, sound detection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Audio Formats
AAC, G.711
Dome
Wired
9.7 cm
9.7 cm
4.83 cm
210 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1536
Motion Detection
Digital Zoom
10
Exposure Range
1/8 sec - 1/10000 sec
Infrared LEDs
Infrared Distance
8 m
Video Capture
1920 x 1536 @ 25 fps
Supported Image Formats
JPEG
Image Sensor
3 MP CMOS 1/3"
Lens Construction
Focal Length
1.1 mm
Lens Iris
F/2.0
Min Focus Distance
30 cm
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
180
Tilting
Range (degree)
15
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS, DSCP
Ports
LAN/power - RJ-45
Supported Memory Cards
microSD Card, microSDXC Card
Mounting kit
C-Tick, FCC, IEEE 802.3af
Power Requirements
DC 12 V / PoE
4.6 Watt
Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 10
Relative Humidity (operating)
