D-Link USB 2.0 4-Port Hub
Customer rating: 5.0* (Write a review)
Quicklinx: 24L6WS00 Mfr#: DUB-H4/B
The D-Link® 4-Port USB 2.0 Hub (DUB-H4) provides four additional USB 2.0 ports to your PC or Mac, allowing you to connect USB devices such as digital cameras, external hard drives, flash drives, and printers. Providing data rates of up to 480Mbps*, this 4-port hub is the ideal solution for transferring data between your computer and external USB storage devices.
Simple plug-and-play
Designed to provide quick and easy access, the DUB-H4 is equipped with four type "A" downstream ports for connecting USB peripherals or other USB hubs. The DUB-H4 does not require any software or complicated installation process. It is a Plug-and-Play device that provides seamless connectivity to both PCs and Macs.
You can simply connect the DUB-H4 to your computer and start connecting your USB devices.
Backward compatible with USB 1.1
The DUB-H4 is backward compatible with USB 1.1** devices, ensuring connectivity between your computer and legacy USB devices. Diagnostic LEDs located on the front of the device provide power state and port status.
The D-Link 4-Port USB 2.0 Hub (DUB-H4) is an excellent choice for adding more USB ports to your computer for connecting your existing peripherals as well as adding the latest USB cameras and external storage devices.
For comparison purposes only. Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
Using a USB 1.1 port will affect device performance.
  • Seamless connections
    The DUB-H4 is designed to provide quick and easy access to the 4 type A downstream ports to connect to peripherals with USB 2.0 support, other USB hubs and devices. A single type B upstream port is provided to connect to the host computer, or another USB hub.
  • Low, full and high speeds supported with data buffering
    As a standard USB hub, it buffers USB data from any attached peripherals or devices in compliance with USB specification versions 1.1 and 2.0 to provide an invisible extension of the USB bus. Supporting both low-speed 1.5Mbps devices, full-speed 12Mbps devices and high speed 480Mbps, each port creates a bridge between the peripheral and host computer.
  • Feature-rich and easy to use
    Diagnostic LED's are mounted on the device to provide the user with power state and port status. The DUB-H4 is packaged with a 6-feet USB 2.0 A-to-B cable, and a DC 5V/2.5A external AC power supply.
Header / Manufacturer
D-Link
USB Hub
Networking / Connectivity Technology
Wired
Ports
4
Header / Packaged Quantity
1
Speed
480 Mbps
Hi-Speed USB
Networking / Form Factor (FE)
Desktop
External
Header / Model
H4
Networking / Type
Hub
Header / Compatibility
PC
Networking / Subcategory (FE)
Peripheral sharing and hubs
Networking / Subtype
USB
Miscellaneous / Compliant Standards
VCCI
Dimensions & Weight / Height
29mm
Dimensions & Weight / Width
63mm
Dimensions & Weight / Depth
104mm
Environmental Parameters / Min Operating Temperature
Environmental Parameters / Max Operating Temperature
24L6 StarTech.com 6 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £7.30
24L6 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.76
24L6 StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.16
24L6 StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £27.00
Customer reviews
Write a review for the D-Link USB 2.0 4-Port Hub here!
D-Link 4-port USB hub
Reviewed by John. Review Posted 15/02/2007
Excellent! 2 minutes to plug it in and it works! What more can I say - it does what it says on the box. I'm using it with a Dabs Value 4 port PCI USB card, did one reboot & all plugins work fine at full speed. This PC lark is getting too simple!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
D Link USB Hub
Reviewed by Steve. Review Posted 02/01/2009
I use two of these with lots of things plugged in. I bought them because the ARE powered. Absolutely no problems, highly recommended.
  • Overall 5*
  • Ease of use 5*
USB Power
Reviewed by . Review Posted 30/11/2008
The hub needs power , as many USB devices draw 5V DC , if you plug four of these into a hub with no power problems occur as the one USB port cant power all four devices,hence the need for a separate power supply,
  • Overall 5*
  • Ease of use 5*
Read all 13 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
