D-Link Unified Services VPN Router
Quicklinx: J7JGWS00 Mfr#: DSR-250V2/B
£206.97 ex VAT
£248.36 inc VAT
The D-Link DSR-250V2 router is designed to meet the demands of small to medium-sized businesses by providing a reliable, high-speed wired connection. This router features a comprehensive suite of interfaces, including Ethernet 10Base-T/100Base-TX/1000Base-T for WAN and LAN, along with a USB 3.0 port for connecting additional devices. With an integrated 4-port switch, it offers flexibility for network expansion and supports various data link protocols such as Ethernet, Fast Ethernet, and Gigabit Ethernet to accommodate a wide range of networking needs.
Advanced features like a DHCP client and an MDI/MDI-X switch ensure efficient network management and easy setup, while remote management protocols like CLI and HTTP allow for convenient monitoring and configuration from anywhere. Whether you're looking to enhance your office network or ensure stable connectivity for your business operations, the D-Link DSR-250V2 provides a robust solution with its versatile connectivity options and powerful networking capabilities.
  • Advanced VPN
    Integrated VPN client and server with support for IPSec, PPTP, L2TP, GRE and OpenVPN tunnels.
  • Failover mode/load balancing
    Dual Gigabit WAN support ensures high availability and load balancing of traffic.
  • Web Content Filtering
    Web Content Filtering functionality to help administrators monitor, manage and control employees' use of the Internet.
  • Captive Portal
    Captive Portal allows employees and guest users to authenticate and authorize themselves with ease.
  • Secure remote connections
    With its comprehensive VPN (IPSec/PPTP/L2TP/GRE/OpenVPN), the DSR-250V2 provides secure connections between mobile or remote employees and the office.
  • Highly configurable and flexible with OpenVPN
    OpenVPN uses various authentication and encryption protocols, such as SSL and TLS, to ensure that user communications are secure and private. Not only is it extremely secure, but it is also easily configurable to provide secure end-to-end or site-to-site connections.
  • High-performance firewall and VPN
    A high-performance firewall with throughput of up to 950 Mbps and VPN (3DES) with throughput of up to 200 Mbps, supporting up to 75 VPN tunnels, allows you to connect more devices, faster.
  • Multi-WAN Support
    Multi-WAN support (via dual Gigabit WAN ports) with WAN failover and load balancing ensures a reliable and stable Internet connection.
  • Access via browser-based authentication
    Captive Portal allows employees and guests to easily authenticate and receive permissions through a customizable welcome page.
  • Application-based control of access priority and bandwidth
    Application Control can limit or prioritize predefined applications in order to effectively manage network utilization.
D-Link DSR-250V2 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Network / Transport Protocol
DHCP
Routing Protocol
OSPF, OSPFv3, RIP-1, RIP-2
Remote Management Protocol
CLI, HTTP
MDI/MDI-X switch, DHCP client, IGMP proxy, IGMP snooping, bandwidth control, ARF
IEEE 802.11q
DC 12 V 1.5 A
12 cm 3.8 cm
Enclosure Type
Desktop
Wired
DHCP
Routing Protocol
CLI, HTTP
IEEE 802.11q, FCC Class B certified, LVD 62368, RCM, VCCI
Status Indicators
Status
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , USB 3.0: 1 x 4 pin USB Type A
External power adapter
DC 12 V
Electric Current Required
1.5 A
8.603 watt
1 x console cable , 1 x network cable
MTBF
1,230,157.85 hours
12 cm
3.8 cm
5 - 95% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: D-Link
