D-Link UNIFIED SERVICE ROUTER
Quicklinx: 7GPLWS00 Mfr#: DSR-500N
  • IEEE 802.11n
D-Link's DSR-500N Unified Services Router is a secure, high performance networking solution to address the growing needs of small and medium businesses. Integrating high-speed Wireless N and USB support, the DSR-500N offers comparable performance to traditional wired networks but with fewer limitations. Optimal network security is provided via features such as virtual private network (VPN) tunnels, IP Security (IPSec), Point-to- Point Tunneling Protocol (PPTP), Layer 2 Tunneling Protocol (L2TP), and Secure Sockets Layer (SSL), making it ideal for SMB and branch offices that need a secure, reliable connection to remote resources.
The DSR-500N includes dual-WAN Gigabit Ethernet which provides policy-based service management, ensuring maximum productivity for your business operations. The Outbound Load Balancing feature1 adjusts outgoing traffic across two WAN interfaces and optimizes the system performance resulting in high availability. The second WAN port can be configured as a DMZ port allowing you to run isolated servers on your LAN.
Designed to deliver superior wireless performance, the DSR-500N includes Wireless N on the 2.4 GHz radio band. Multiple In Multiple Out (MIMO) technology allows DSR-500N to provide high data rates with minimal "dead spots" throughout the wireless coverage area.
A fully featured virtual private network (VPN) provides your mobile workers and branch offices with a secure link to your resources. Site-to-site VPN tunnels use IP Security (IPSec) Protocol, Point-to-Point Tunneling Protocol (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office connectivity through encrypted virtual links.
As a concerned member of the global community, D-Link is devoted to providing eco-friendly products, which save power and money while extend the product's lifespan. The D-Link Green WLAN Scheduler reduces wireless power automatically during off-peak hours. Likewise the D-Link Green Ethernet technology adjusts power usage based on the detected cable length and link status. In addition, compliance with RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives make D-Link Green certified devices the environmentally responsible choice.
  • Comprehensive management capabilities
    The DSR-500N includes dual-WAN Gigabit Ethernet which provides policy-based service management ensuring maximum productivity for your business operations. The failover feature maintains data traffic without disconnecting when a landline connection is lost. The outbound load balancing feature adjusts outgoing traffic across two WAN interfaces and optimizes the system performance resulting in high availability. The second WAN port can be configured as a DMZ port allowing you to isolate servers from your LAN.
  • Superior wireless performance
    Designed to deliver superior wireless performance, the DSR-500N includes 802.11b/g/n allowing for operation on the 2.4 GHz radio band. Multiple In Multiple Out (MIMO) technology allows the DSR-500N to provide high data rates with minimal "dead spots" throughout the wireless coverage area.
  • Robust VPN features
    A fully featured virtual private network (VPN) provides your mobile workers and branch offices with a secure link to your network. The DSR-500N are capable of simultaneously managing 10 Secure Sockets Layer (SSL) VPN tunnels respectively, empowering your mobile users by providing remote access to a central corporate database.
  • Efficient green technology
    The D-Link green WLAN scheduler reduces wireless power automatically during off-peak hours. Likewise the D-Link green Ethernet program adjusts power usage based on the detected cable length and link status. In addition, compliance with RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives make D-Link green certified devices the environmentally responsible choice.
D-Link Wireless Services Router DSR-500N - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
1 Gbps
Performance
Firewall throughput: 70 Mbps , VPN throughput: 35 Mbps
Concurrent sessions: 30000 , VPN tunnels: 35 , SSL VPN tunnels: 10 , Firewall policies: 300
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Firewall protection, DMZ port, dynamic IP address assignment, DHCP support, NAT support, VPN support, PAT support, VLAN support, content filtering, IPv6 support, IPS, URL filtering, firmware upgradable, MIMO technology, IPSec VPN, WPA2 encryption, QoS, DPD, IPSec NAT-T, WPS, DHCP server, Multiple SSID support, Green Ethernet, Green WLAN, D-Link Green Technology
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
28 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
1 Gbps
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, Blowfish, Twofish, AES, SSL, TLS, PEAP, TTLS, WPA, WPA2, CAST-128, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, FCC Class B certified, VCCI, C-Tick, cUL, IC, RoHS, EN 60950-1, WEEE
Status Indicators
Port status, link/activity
WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
2 dBi
Internal power supply
MTBF
260,000 hours
28 cm
18 cm
4.4 cm
5 - 95% (non-condensing)
7GPL C2G 2m USB 2.0 A/B Cable - Black In Stock £4.03
