The D-Link DSR-1000AC Wireless AC Unified Services VPN Router provide secure, high-performance networking solutions to address the growing needs of small and medium businesses. Next generation wireless performance provides wireless speeds of up to 1300 Mbps.
Comprehensive management solution
Active-Active WAN port features such as auto WAN failover and load balancing, ICSA-certified firewall, and D-Link Green Technology make this a reliable, secure and economic choice to manage your network. -
Complete VPN features
With fully featured VPN as well as IPSec Hub and Spoke technology, secure communication between mobile employees and offices can be easily configured and guaranteed in any environment. -
Web authentication capabilities
Captive portal allows employees and guest users to be easily authenticated and authorized by accessing customized landing pages.
- D-Link DSR-1000AC - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Firewall throughput: 950 Mbps , VPN throughput (3DES): 100 Mpps
- Capacity
- Concurrent sessions: 60000 , VPN tunnels: 135 , Firewall policies: 600 , IPSec tunnels: 70 , SSL VPN tunnels: 20
- PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
- Routing Protocol
- OSPF, RIP-1, RIP-2, static IP routing, GRE
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
- NAT support, PAT support, VLAN support, content filtering, port mirroring, IPv6 support, IPS, QoS, WPS, DHCP server, Multiple SSID support, bandwidth control, DHCP relay, DHCP client, TRTCM, SRTCM
- IEEE 802.1Q, IEEE 802.1x
- 28 cm x 18 cm x 4.4 cm
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, Blowfish, Twofish, AES, SSL, PEAP, CAST-128, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
- Authentication Method
- RADIUS
- IEEE 802.1Q, IEEE 802.1x, FCC Class B certified, VCCI, C-Tick, cUL, IC, EN 60950-1, LVD
- Status Indicators
- Port status, link/activity
- WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- 19.3 watt
- MTBF
- 260,000 hours
- 28 cm
- 18 cm
- 4.4 cm
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
D-Link Unifed service Router
