D-Link Switch-Managed-48 x 10/100/1000 + 4 x 10Gb Ethernet SFP
Quicklinx: D0WTWS00 Mfr#: DGS-3000-52X
52-Port Gigabit Layer 2 Managed Switch including 4 x 10GE SFP+ ports. The DGS-3000 Series Gigabit L2 Managed Switches feature a variety of ports, including 10/100/1000BASE-T RJ-45 ports, 1G SFP ports, and 10G SFP+ ports for increased network bandwidth. Surge protection, advanced Layer 2 functions, and a suite of security and management tools make the DGS-3000 Series Gigabit L2 Managed Switches ideal for Metro Ethernet and campus applications.
  • Robust performance
    With a switching capacity of 176 Gbps and forwarding performance of 130.95 Mpps, this switch is designed to handle intensive data traffic, ensuring smooth and efficient network operations.
  • Comprehensive connectivity
    Equipped with 48 10/100/1000 ports and 4 10Gb Ethernet SFP+ ports, the D-Link DGS 3000-52X offers a wide range of connection options for various networking needs, supporting both high-speed and legacy devices.
  • Advanced network security
    Features such as ARP support, DoS attack prevention, Extensive Access Control List (ACL) support, and D-Link's Safeguard Engine provide a secure networking environment, protecting against external threats and unauthorized access.
  • Efficient network management
    Support for SNMP, RMON, SSH, and Telnet allows for flexible and comprehensive remote management, enabling efficient monitoring and control of network resources.
  • Enhanced durability
    With a MTBF of 465,240 hours, 6 kV Surge protection, and a robust design featuring 2 fans, this switch is built to withstand demanding operational environments, ensuring long-term reliability and performance.
D-Link DGS 3000-52X - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10Gb Ethernet SFP+
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH
Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, Dying Gasp support, QoS, Safeguard Engine, NAP, LLDP support, RSPAN, CoS, D-Link SIM, ERPS, 2 fans, 3MB packet buffer, 6KV Surge protection, VLAN mirroring, WAC, CFM, Extensive ACL support, Guest VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX
44 cm x 21 cm x 4.4 cm
2.4 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Status Indicators
Power, RPS (Redundant Power Supply), fan, console, link/activity/speed
48 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management
Internal power supply
40.7 Watt
4 rubber feet
1 x console cable
Rack Mounting Kit
Included
MTBF
465,240 hours
VCCI, C-Tick, BSMI, cUL, IEC 61000-4-5, CB, FCC, ITU-T G.8032
44 cm
21 cm
4.4 cm
2.4 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
