Product
D-Link Switch-Managed-24 x 10/100/1000 + 4 x 10Gb Ethernet SFP
Quicklinx: D0WSWS00 Mfr#: DGS-3000-28XMP
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£549.29 ex VAT
£659.14 inc VAT
28-Port Gigabit Layer 2 Managed Max PoE Switch including 4 x 10GE SFP+ ports. The DGS-3000 Series Gigabit L2 Managed Switches feature a variety of ports, including 10/100/1000BASE-T RJ-45 ports, 1G SFP ports, and 10G SFP+ ports for increased network bandwidth. Surge protection, advanced Layer 2 functions, and a suite of security and management tools make the DGS-3000 Series Gigabit L2 Managed Switches ideal for Metro Ethernet and campus applications.
D-Link DGS 3000-28XMP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10Gb Ethernet SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance (64-byte packet size): 95.24 Mpps
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, SSH
Flow control, auto-negotiation, ARP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, Dying Gasp support, Quality of Service (QoS), Safeguard Engine, Network Access Protection (NAP), LLDP support, Remote Switch Port Analyzer (RSPAN), Class of Service (CoS), D-Link Single IP Management (SIM), Ethernet Ring Protection Switching (ERPS), 2 fans, 1.5MB packet buffer, 6KV Surge protection, VLAN mirroring, Web-based Access Control (WAC), Connectivity Fault Management (CFM), Extensive Access Control List (ACL) support, Guest VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ah, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX
44 cm x 30.8 cm x 4.4 cm
4.25 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Status Indicators
Power, RPS (Redundant Power Supply), fan, console, link/activity/speed
24 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management
Internal power supply
4 rubber feet
1 x console cable
Rack Mounting Kit
Included
MTBF
268,693 hours
VCCI, C-Tick, BSMI, cUL, IEC 61000-4-5, CB, FCC, ITU-T G.8032
44 cm
30.8 cm
4.4 cm
4.25 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
Brand: D-Link
Price Range Ex VAT: 500 - 750
