D-Link's DNS-1560-04 is a unified solution for these growing data storage requirements, and provides a multitude of options for managing and securing important files. The ShareCenter Pro 4-Bay 1U Rackmount Unified Storage enables users to safely share and back-up mission critical data. This NAS/iSCSI storage solution includes advanced features such as ZFS file system, thin provisioning, compression, snapshots and replication usually found only in higher-end devices, with no need to purchase additional licenses.
Unified storage solution
The DNS-1560 is a unified solution that provides iSCSI and NAS functionalities. It boasts strong iSCSI read/write performance with average data throughput higher than many competing products. It also provides versatile RAID support meaning you never run the risk of losing valuable data. It features 4 Serial ATA (SATA) disk drive bays that support hard drives in RAID level 0, 1, 5, 6, 10, or JBOD configurations. DNS-1560 supports multiple protocols including SMB, NFS, AFP, FTP, WebDAV as well as iSCSI. This combination delivers storage solutions with great performance, manageability and efficiency -
Variety of backup options
The DNS-1560 offers several backup options which allow administrators and users to control how, when, and where their data is stored. Share files across the network or over the Internet via FTP or access them via the easy-to-use web file manager. Remote back-up enables users to keep a copy of their files on a remote NAS for a disaster recovery solution, providing extra data protection, and volume snapshots can restore a whole volume in a matter of minutes; in contrast to traditional backup schemes that can take hours. -
Efficiency and redundancy
The DNS-1560 features thin provisioning allocating disk storage space in a flexible manner based on the minimum space required. It also addresses the explosion of unstructured data and files, where reads/writes are random, by treating random writes as sequential blocks. Furthermore, the 4 Serial ATA (SATA) disk drive bays supports RAID level 0, 1, 10, 5, 6 or JBOD configurations. Administrators can quickly deploy a network storage solution using inexpensive SATA disk drives, and depending on storage needs, can add more drives as they go. Additionally, S.M.A.R.T. disk diagnostics help to ensure data integrity. -
Energy efficient
The DNS-1560 is 80 PLUS certified. 80 PLUS certification is granted to products that have more than 80% energy efficiency at certain levels of rated load. This enables the DNS-1560 to run more efficiently by using less electricity, allowing it to run cooler and with reduced operating costs. -
Manageability
The DNS-1560 has an intuitive web user interface, which dramatically increases usability for enterprise users, making it easy to setup, configure and manage. It also integrates Windows Active Directory and LDAP for IT administrators to easily manage accounts in enterprise environments.
- D-Link ShareCenter Pro 1560 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 1U
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 44.2 cm x 53.34 cm x 4.4 cm
- 7.7 kg ()
- Processor
- 1 x Intel Atom D2550 1.86 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.2 cm
- 53.34 cm
- 4.4 cm
- 7.7 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 4 GB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Data Link Protocol
- iSCSI, FTP, DHCP, SMB
- Remote Management Protocol
- SNMP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS
- Firewall protection, DHCP support, wake on LAN (WOL), E-mail alert, SSH support, Jumbo Frames support, Link Aggregation Control Protocol (LACP)
- IEEE 802.3ad (LACP)
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x VGA
- Wake on LAN
- BSMI, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 2
- Power Redundancy
- Voltage Required
- Power Provided
- 226 Watt
- 80 PLUS Certification
- 80 PLUS
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
