The D-Link DGS-712 1000BASE-T Copper Small Form Pluggable (SFP) transceiver is based on the SFP Multi Source Agreement (MSA). It is compatible with the Gigabit Ethernet and 1000BASE-T standards as specified in IEEE Std 802.3z and IEEE Std 802.3ab. The 1000BASE-T physical layer IC (PHY) can be accessed via I2C, allowing access to all PHY settings and features.
The DGS-712 1000BASE-T copper SFP transceiver plugs into an SFP slot provided for on a D-Link Gigabit switch or optional switch module. It provides Gigabit transmission on the common Category 5 twisted-pair network cable.
Enhanced connectivity
The D-Link DGS 712 SFP (mini-GBIC) transceiver module offers Ethernet 1000Base-T connectivity, ensuring high-speed wired Internet access for efficient networking. -
Wide temperature range
Designed to operate in a broad range of temperatures, from 0°C to 85°C, this transceiver module is suitable for various environmental conditions, making it a reliable choice for different operational scenarios. -
Easy integration
With its plug-in module form factor and compatibility with PC systems, the D-Link DGS 712 seamlessly integrates into existing network infrastructures, providing an effortless upgrade path for enhancing network performance.
 - D-Link DGS 712 - SFP (mini-GBIC) transceiver module - 1GbE
 - SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
 - Plug-in module
- Cabling Type
 - 1000Base-T
- Data Link Protocol
 - 1GbE
- Designed For
 - DES 3028, 3052, 3526, 3550; DGS 1210-10, 1216, 1248, 3100-24, 3100-48, 3200-10, 3200-16; DXS 1210-12; Nuclias Cloud-Managed DBS-2000-28, 2000-52; Web Smart DES-1228, 1252, DGS-1216, 1224, 1248; xStack DES-3526, 3528, 3552, 3828, 3852, DGS-3426, 3427, 3450, 3612, 3627, 3650
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 1000Base-T
 - 1GbE
 - Auto-sensing per device
 - IEEE 802.3z, IEEE 802.3ab
 - 1 x Ethernet 1000Base-T - RJ-45
- Compatible Slots
 - 1 x SFP (mini-GBIC)
 - 0 °C
 - 85 °C
- Designed For
 - D-Link DES 3028, 3028P, 3052, 3052P, 3526, 3550 , D-Link DGS 1210-10P/ME, 1216T, 1248T, 3100-24, 3100-24P, 3100-24TG, 3100-48, 3100-48P, 3200-10, 3200-16 , D-Link DXS 1210-12SC , D-Link Nuclias Cloud-Managed DBS-2000-28MP, DBS-2000-52MP , D-Link Web Smart DES-1228, DES-1252, DGS-1216T, DGS-1224T, DGS-1248T , D-Link xStack DES-3526, DES-3528, DES-3528P, DES-3552, DES-3828, DES-3828DC, DES-3828P, DES-3852, DGS-3426, DGS-3426P, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650
