The D-Link's DEM- 210 SFP transceiver provides a high performance solution for serial optical data communication applications. It is hot swappable, Small Form Factor Pluggable (SFP) compliant with the Multi-Source Agreement (MSA) specification. The transceiver has duplex LC connectors and provides IEEE 802.3u compliant link for up to 100Mbps in the half duplex mode (or 200Mbps full-duplex mode) transmission for fiber cable applications.
D-Link's highly integrated transceiver offers low jitter performance for extended optical links support without performance degradation. This high performance enables reliable data transfer in short-, intermediate- and long-distances for building, factory, campus and metropolitan networking applications.
- D-Link DEM 210 - SFP (mini-GBIC) transceiver module - 100Mb LAN
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 15 km
- Designed For
- DES 1210; xStack DES-3552
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100Mb LAN
- 100 Mbps
- 1310 nm
- 15 km
- Half duplex mode
- IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
- 1 x Ethernet 100Base-FX - LC single-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- FCC Class B certified, UL, TUV, VCCI, ICES-003, RoHS
- 0 °C
- 70 °C
- 10 - 90%
- Designed For
- D-Link DES 1210 , D-Link xStack DES-3552
