D-Link SFP+ 10GBASE-T Copper Transceiver
Quicklinx: J7LVWS00 Mfr#: DEM-410T
£156.00 ex VAT
£187.20 inc VAT
The D-Link XFP module provides high-speed connection on the secure fiber cable. It provides XFP slots and can be slid into an open slot of a D-Link Gigabit switch. The D-Link XFP module allows flexible deployment of high speed connection and is ideal for bandwidth-hungry applications that can meet greater cable distances and low signal interference requirements in the Local Area Network, Wide Area Network and Metropolitan Area Network.
  • Robust connectivity
    The D-Link DEM 410T SFP+ transceiver module offers Ethernet 10GBase-T connectivity, ensuring high-speed data transfer rates of up to 10 Gbps. This feature enables efficient networking capabilities suitable for a variety of applications.
  • Durable and reliable
    With an MTBF of 217,186 hours, the D-Link DEM 410T is built for longevity and reliability. This ensures minimal downtime and a dependable networking solution for your business.
  • Wide operating range
    Designed to operate in a wide range of environmental conditions, the D-Link DEM 410T can function in temperatures from 0°C to 65°C and humidity ranges from 5% to 95%. This versatility makes it suitable for deployment in diverse operational environments.
  • Comprehensive compliance
    The D-Link DEM 410T meets a variety of compliance standards, including FCC, LVD, MSA SFF-8431, MSA SFF-8432, RoHS, and VCCI. This compliance ensures that the module adheres to rigorous safety and environmental standards, making it a responsible choice for your networking needs.
D-Link DEM 410T - SFP+ transceiver module - 10GbE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
30 m
1.37 cm x 6.8 cm x 0.85 cm
20 g
Plug-in module
Wired
Cabling Type
10GBase-T
10GbE
Data Transfer Rate
10 Gbps
30 m
IEEE 802.3an, IEEE 802.3ab
1 x Ethernet 10GBase-T - RJ-45 female
MTBF
217,186 hours
FCC, VCCI, LVD, RoHS, MSA SFF-8431, MSA SFF-8432
0.5 watt
1.37 cm
6.8 cm
0.85 cm
20 g
65 °C
5 - 95%
Brand: D-Link
