Upgrade your computer's Wi-Fi and access the Internet quickly and easily from anywhere in your home or office. This adapter delivers high performance wireless networking to a notebook via the PCI interface.
Wireless N technology offers more speed, extended coverage and virtually no dead spots while still compatible with previous network standards. This adapter transfers data at speeds of up to 300 Mbps.
The DWA-547 supports WEP, WPA and WPA2 encryption methods and includes a configuration utility to find available wireless networks and show quality/signal strength.
No experience required, simply insert the enclosed CD into your computer and the installation wizard will do the rest.
Ultimate performance
The RangeBooster N 650 desktop adapter is a draft 802.11n client device that delivers unrivaled wireless performance for the desktop PC. Users can easily upgrade to the next generation of wireless technology by adding the RangeBooster N 650 adapter to access network high-speed Internet connection while sharing photos, files, music, video, printers, and storage. Enhance Internet experience with a faster wireless connection and enjoy smooth digital phone calls, gaming, downloading, and video streaming. -
Get connected, stay connected
Powered by RangeBooster N 650 technology, this adapter provides wireless performance that is up to 5 times farther than 802.11g. This high performance wireless adapter is designed for use in bigger homes and for users that demand higher networking performance. Maximize wireless performance by connecting this adapter to a RangeBooster N router and stay connected from virtually anywhere in your home. It can also be used with 802.11g and 802.11b wireless networks to enable significantly improved reception. This adapter supports WPA/WPA2 security and WEP data encryption to help prevent outside intrusion and protect your personal information from being exposed. -
Easy to setup, easy to use
A quick setup wizard guides users step-by-step through the installation process. Configure this adapter without having to call a networking expert for help. The wireless manager is included with this product to keep track of all most frequently accessed networks. With unmatched wireless performance, reception, and security, this adapter is the best choice for easily adding or upgrading wireless connectivity to desktop computers.
- D-Link RangeBooster N DWA-547 - network adapter - PCI
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- PCI Specification Revision
- PCI 2.3
- 1.9 cm x 13.4 cm x 12.1 cm
- 107 g
- Data Link Protocol
- 802.11b/g, 802.11n (draft)
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- System Requirements
- Microsoft Windows 2000 SP4, Microsoft Windows XP SP2
- Microsoft Certification
- Certified for Windows Vista
- Network adapter
- Form Factor
- Plug-in card
- PCI
- PCI 2.3
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM, DSSS
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link OK, link/activity
Aerial
- Antenna
- External detachable
- Directivity
- Omni-directional
- Gain Level
- 2 dBi
- Compatible Slots
- 1 x PCI
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- FCC Class B certified, C-Tick, IC
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM
- System Requirements Details
- HD 20 MB
- 1.9 cm
- 13.4 cm
- 12.1 cm
- 107 g
- 0 °C
- 40 °C
- 10 - 90%
Resources
The following resources are available for the D-Link RangeBooster N 650 Desktop Adapter DWA-547
Customer reviews
Write a review for the D-Link RangeBooster N 650 Desktop Adapter DWA-547 here!
RangeBooster
Reviewed by Adam Gale. Review Posted 04/05/2007
Excellent bit of kit, easy to install and easy to use. Is abit expensive though, also havent had chance to test it on vista yet. Excellent Dabs service as per usual!
Overall
Ease of use
Value for money
an improvement over 54g
Reviewed by Anonymous Review Posted 21/08/2007
In conjunction with a D-link DIR-655 router I've not had any problems or disconnections, so the connection is reliable for me. Its not a massive improvement over 54g,gaming pings and range but max bandwidth is in the hundreds rather than tens of Mb.
Had to play with netstumbler and twiddle the antennas to get the best out of it on both the router and NIC.
Basically I wouldn’t upgrade an entire network to N if I already had G and it was working fine, but these N products are a real world improvement or if you are a sucker for new-Tech(like me) or if extra wifi encryption is needed.
Note this card is fairly large and may not fit in a low riser PCI slot(e.g. HTPC).
Overall
Ease of use
Value for money
WOT! No Vista Drivers?
Reviewed by Scott Bell. Review Posted 03/06/2008
I bought this, along with DIR-635 router and DWA-643 notebook adapter.
Installation of the drivers was not the most staightforward, but I got them installed.
Under XP it works like a dream, blistering fast transfers transfers between the 'N' enabled equipment and no drop-outs where previously wireless was a pain.
I then bought a new Vista desktop and decided to put the adapter into this. FORGET IT. There are no Vista drivers. After several emails to D-Link, who keep promising Vista drivers 'soon', They eventually pointed my to their Swedish site who had released drivers. Downloaded these and still no joy. BSOD's.
D-Link don't seem to develop their own frivers, relying on the chipset manufacturers. This is a great pity as this works under XP. D-Link, bow your head in shame.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
