D-Link Radio access point - 802.11a/b/g/n/ac - Dual Band
Quicklinx: D0WMWS00 Mfr#: DWL-6610APE
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11b + 1 more
Compatibility: PC
  • IEEE 802.11n
£176.97 ex VAT
£212.36 inc VAT
The DWL-6610APE Wireless AC1200 Dual-Band Unified Access Point is designed for small to medium businesses and enterprises, providing unparalleled bandwidth and flexibility for medium to large scale Wi-Fi networks. Featuring the latest 802.11ac technology on its 5 GHz band, the DWL-6610APE allows you to deploy more devices and provide greater throughput for your wireless clients. The DWL-6610APE provides unparalleled connectivity by using a 2 x 2 antenna implementation, allowing high combined data rates of 1167 Mbps (867 Mbps2 for 802.11ac, and 300 Mbps2 for 802.11n) over the air. With 802.11n/ac technology, the DWL-6610APE provides high-performance connections over two bands, so wireless clients can stream media faster and farther than before using existing devices. When working in conjunction with D-Link Unified Controllers, the DWL-6610APE can be centrally managed. This allows for a large number of APs to be deployed and managed easily and efficiently. Once the APs are discovered by the controller, the administrator can push configuration to them as a group, instead of doing so individually. Additionally, Radio Frequency (RF) resource management allows wireless coverage to be managed centrally, proving the best coverage possible for wireless clients.
  • Enhanced connectivity
    Equipped with a 1000Base-T (PoE) RJ-45 connector, this wireless access point ensures high-speed data transfer and power over Ethernet for efficient deployment.
  • Robust security
    Featuring a comprehensive suite of encryption algorithms including 128-bit WEP, 64-bit WEP, AES, TKIP, WPA, WPA-PSK, and WPA2-PSK, it offers superior protection against unauthorized access.
  • Versatile performance
    Supports multiple Wi-Fi bands (2.4 GHz and 5 GHz) and Wi-Fi 5 technology, catering to a wide range of devices and offering enhanced network efficiency.
  • Advanced networking features
    Comes with 802.1x authentication, MAC address filtering, Multiple SSID support, Quality of Service (QoS), VLAN support, and more, enabling flexible network management and optimization.
  • Easy management
    Remote management protocols such as HTTP, HTTPS, SNMP, SSH, and Telnet allow for convenient and secure configuration and monitoring of the network.
D-Link DWL-6610APE - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
Radio access point
External
Wireless
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN
Power over Ethernet (PoE), load balancing, VLAN support, MAC address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, rogue access point detection, 802.1x authentication, WDS bridge, Link Integrity
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA-PSK, WPA2-PSK
IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna Qty
4
1 x 1000Base-T (PoE) - RJ-45
C-Tick, BSMI, cUL, IC, UL 2043, FCC, LVD, NCC, EN 300 328 V1.8.1:2012, ETSI EN 301 893 V1.7.1
PoE
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Compatibility: PC
Brand: D-Link
