D-Link - Power adapter - 36 Watt - United Kingdom, Europe - black
Quicklinx: FZBWWS00 Mfr#: PSM-12V-38-B
£13.84 ex VAT
£16.60 inc VAT
The D-Link power adapter is an efficient external power solution designed to meet the needs of PC users requiring a reliable 12 V power source. With a maximum electric current of 3 A, it delivers a consistent 36 W of power, ensuring your device operates smoothly without interruption. The adapter comes equipped with a durable 1.1 m power cable and a power DC jack 3.8 mm connector, making it versatile for a wide range of setups. Its compact and robust design not only makes it easy to transport but also ensures it stands up to the demands of daily use. Whether you're at home, in the office, or on-the-go, this power adapter is the perfect solution for keeping your PC powered and ready to go.
  • Efficient power supply
    The D-Link power adapter ensures your PC remains powered with a steady supply of 36 W, making it ideal for maintaining optimal performance without the risk of power dips or surges.
  • Compact and durable design
    Designed with portability in mind, the power adapter features a compact form factor and a robust 1.1 m power cable, ensuring it can withstand the rigors of daily use while being easy to carry.
  • Seamless compatibility
    With a power DC jack 3.8 mm connector, this adapter is crafted to provide a seamless fit for PCs requiring a 12 V power input, ensuring a reliable connection and efficient power delivery.
D-Link - power adapter - 36 Watt
Power adapter - external
Output Voltage
12 V
Power Capacity
36 Watt
Input Connectors
Power DC jack 3.8 mm
Output connectors
1 x power DC jack 3.8 mm - 12 V 3 A
Input Connectors
Output Voltage
12 V
Max Electric Current
3 A
Power Capacity
36 Watt
Power cable 1.1 m
Brand: D-Link
