D-Link PoE injector - 30 Watt
Quicklinx: CY76WS00 Mfr#: DPE-301GI
Type: PoE Kit
13 In Stock
£16.76 ex VAT
£20.11 inc VAT
The IEEE 802.3at (PoE+)/802.3af (PoE) compliant DPE-301GI Gigabit PoE+ Injector is designed to supply data and up to 30 watts of power to PoE-enabled devices such as network cameras and wireless access points.
  • Efficient power supply
    The D-Link DPE-301GI PoE injector is designed to supply power up to 30 W, ensuring that your high-power devices receive the energy they need to operate efficiently.
  • Wide operating range
    With an operating humidity range of 5 - 95% (non-condensing) and a maximum operating temperature of 50°C, this PoE injector is built to perform reliably in a variety of environmental conditions.
  • Universal compatibility
    Featuring an RJ-45 connector, the DPE-301GI is compatible with a wide range of network devices, making it a versatile solution for your power supply needs.
D-Link DPE-301GI - PoE injector - 30 watt
PoE injector - external
70 g
Output Voltage
54 V
Power Capacity
30 watt
Output connectors
1 x RJ-45
Power adapter
10.98 cm x 6.22 cm x 2.45 cm
1 x RJ-45
Output Voltage
54 V
Power Capacity
30 watt
Power adapter
Network cable - external
UL, VCCI, BSMI, CB, CCC, IC, FCC, RoHS, RCM
50 °C
10.98 cm
6.22 cm
2.45 cm
70 g
Type: PoE Kit
Brand: D-Link
