The D-Link DCS-7513 Full HD WDR day and night outdoor network camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 2-megapixel progressive scan CMOS sensor with a motorized P-Iris lens and onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera ideal for reliable deployment in surveillance applications without the need for accessories.
High-quality video
The DCS-7513 is equipped with a P-Iris lens that controls the iris with extreme precision. Its built-in stepping motor maintains the Iris opening at an optimal level at all times, resulting in superior image quality, clarity, and depth of field. The remote focus function eliminates the need for manual focusing at the camera's position and allows you to make adjustments from any computer. To maximize bandwidth deficiency and improve image quality, the DCS-7513 provides real-time video compression using the H.264, MPEG-4 and MJPEG codecs and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory. Furthermore, bandwidth requirements can be adjusted in real-time over the network, and recorded video files can be saved to network attached storage (NAS) device or SD card. -
Continuous monitoring
The DCS-7513 WDR image enhancement gives you improved image quality in environments with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly lit areas. In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-7513 is also built with IR LED illuminators with a 30 meter range, allowing the camera to keep watch even in complete darkness. -
The DCS-7513 has a built-in 802.3af compliant PoE module that eases installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
- D-Link DCS 7513 Full HD WDR Day & Night Outdoor Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- Camera Mount Type
- Wall mount
- 2.05 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3 x
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 0 lux - IR
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 9 mm
- Focus Adjustment
- Manual
- Lens Iris
- F/1.2
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Motion sensor, date/time stamp, sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), SDHC-card slot, heater, ONVIF support, built-in cooling fan, built-in LED illuminator, infrared cut filter, P-Iris control
- Environmental Parameters (operating)
- -40 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Wall mount
- Wired
- 2.05 kg
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Digital Zoom
- 10
- 0 lux - IR
- Supported Image Formats
- JPEG
Image Sensor
- 2 MP CMOS 1/2.8"
Lens Construction
- Vari-focal
- Optical Zoom
- 3 x
- Focal Length
- 3 mm - 9 mm
- Lens Iris
- F/1.2
- Focus Adjustment
- Manual
- Horizontal Field of View (degree)
- 38.1 - 121.2
- Vertical Field of View (degree)
- 21.3 - 62.1
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Sunshield
- C-Tick, FCC, IP66
- Power Requirements
- DC 12 V / PoE
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 11 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
