D-Link Nuclias Connect AX3000 Outdoor Access Point
Quicklinx: J7JTWS00 Mfr#: DAP-X3060OU
£204.68 ex VAT
£245.61 inc VAT
The D-Link DAP-X3060OU is a wireless access point designed to offer connectivity and security for outdoor environments. With its ruggedized design, this device can operate in extreme temperatures ranging from -30°C to 60°C, making it ideal for any outdoor setting. It supports Wi-Fi 6 technology, ensuring faster speeds, increased capacity, and reduced network congestion.
The DAP-X3060OU boasts advanced security features, including a variety of encryption algorithms like WPA3-Personal and Enterprise, to protect against unauthorized access and ensure safe network communication. It is capable of supporting up to 16 configured SSIDs, with 8 SSIDs per radio, allowing for extensive network customization and segmentation. Additionally, features such as Energy-Efficient Ethernet (EEE) and Power over Ethernet (PoE+) support not only promote efficient power usage but also maintain high performance, making the DAP-X3060OU an excellent choice for businesses looking to deploy a reliable and secure outdoor wireless network.
  • Robust design
    Engineered for the outdoors, the DAP-X3060OU features a ruggedized design that stands up to extreme weather conditions, ensuring reliable performance from -30°C to 60°C.
  • Enhanced security
    Offers a comprehensive suite of encryption algorithms including WPA3-Personal and Enterprise, ensuring a high level of security for network communications.
  • High-capacity connectivity
    Supports up to 16 configured SSIDs, with 8 SSIDs per radio, allowing for extensive network customization and segmentation.
  • Advanced networking
    Equipped with Wi-Fi 6 technology, the device provides faster speeds, increased capacity, and reduced network congestion.
  • Efficient operation
    Features such as Energy-Efficient Ethernet (EEE) and Power over Ethernet (PoE+) support ensure efficient power usage while maintaining high performance.
D-Link DAP-X3060OU - radio access point - outdoor - Wi-Fi 6
Radio access point
Wall / pole mountable - outdoor
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps , Channel bandwidth: 160 MHz
Maximum number of configured SSIDs: 16 , SSIDs per radio: 8
Pole/wall mount kit
Power Over Ethernet (PoE) Supported
PoE+
27.7 cm x 5 cm x 24 cm
612.4 g
Radio access point
Ruggedized Design
Outdoor
27.7 cm
5 cm
24 cm
612.4 g
Wireless
Line Coding Format
OFDMA
Spread Spectrum Method
OFDMA
Network / Transport Protocol
HTTP
Routing Protocol
Static IP routing
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX3000
Status Indicators
Power, status
Manageable, Access Control List (ACL) support, POP3 proxy, reset button, Captive Portal, 802.1x authentication, band steering, WDS access point, Energy-Efficient Ethernet (EEE), dustproof, waterproof, RADIUS Server, AD domain, SSID broadcast
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA-Enterprise, WPA2-Enterprise, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
Authentication Method
RADIUS, Radio Service Set ID (SSID), LDAP
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1/2.5GBase-T (PoE+) - RJ-45 , 1 x console - RJ-45
Pole/wall mount kit
MTBF
30,000 hours
UL, IEC 60601-1-2, FCC, IP68
PoE+
External power adapter
-30 °C
60 °C
10 - 90%
Brand: D-Link
