Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges.
Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home. -
Peace of mind
Smart smoke detector with built-in 85dB loud audio alarm that can also send a push notification to your smartphone and tablet. -
Battery powered
Battery powered with low battery indication via push notification through the mydlink Home app, allows you to stay informed on when the battery needs changing. -
Your mydlink Home
mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter. -
Set up, control, monitor and protect your home
The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink home devices.
- mydlink Home Smoke Detector - smoke sensor - Z-Wave
- Product Type
- Smoke sensor
- Functions
- Siren
- Integrated Components
- Alarm
- Connectivity
- Wireless - Z-Wave
- Supported Host Device OS
- iOS, Android
- 12 cm x 5.3 cm x 12 cm
- Product Type
- Smoke sensor
- Functions
- Siren
- Alarm
- Connectivity Technology
- Wireless - Z-Wave
- iOS, Android
- Push notification
- Included Accessories
- CR123A lithium battery
- Encryption Algorithm
- 128-bit AES
- FCC
- 12 cm
- 5.3 cm
- 12 cm
- 130 g
- 0 °C
- 49 °C
- 10 - 85% (non-condensing)
