The mydlink Home Siren is a smart audio warning device with 6 different sounds built-in. It’s easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub.
mydlink Home Siren with optional battery back-up
The mydlink Home Siren is a smart audio warning device with 6 different sounds built-in. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. Whether you are at home or away, push notifications will alert you whenever the Siren is activated. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges. -
Peace of mind
Instant audio alarm, with volume up to 110dB, when a linked mydlink Home Sensor is triggered. -
6 different sounds
Equipped with six different sounds: door chime, arm/disarm, intruder alarm, fire alert, ambulance and police car sounds, you can customize your smart home by selecting the appropriate sound effect or alarm whenever a different event occurs. -
Your mydlink Home
mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter. -
Set up, control, monitor and protect your home
The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink home devices.
- mydlink Home Siren - siren - Z-Wave
- Product Type
- Siren
- Connectivity
- Wireless - Z-Wave
- Supported Host Device OS
- iOS, Android
- 11 cm x 11 cm x 1.9 cm
- Product Type
- Siren
- Connectivity Technology
- Wireless - Z-Wave
- iOS, Android
- Push notification
- Encryption Algorithm
- 128-bit AES
- FCC
- 11 cm
- 11 cm
- 1.9 cm
- 125 g
- -10 °C
- 40 °C
- 20 - 90% (non-condensing)
