D-Link mydlink Home Siren with battery back-up
Quicklinx: CFZ9WS00 Mfr#: DCH-Z510
Type: Siren
Stock Status: Clearance
Hurry, only 1 left in stock!
£40.75 ex VAT
£48.90 inc VAT
Express delivery Delivered on Tuesday
The mydlink Home Siren is a smart audio warning device with 6 different sounds built-in. It’s easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub.
  • mydlink Home Siren with optional battery back-up
    The mydlink Home Siren is a smart audio warning device with 6 different sounds built-in. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. Whether you are at home or away, push notifications will alert you whenever the Siren is activated. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges.
  • Peace of mind
    Instant audio alarm, with volume up to 110dB, when a linked mydlink Home Sensor is triggered.
  • 6 different sounds
    Equipped with six different sounds: door chime, arm/disarm, intruder alarm, fire alert, ambulance and police car sounds, you can customize your smart home by selecting the appropriate sound effect or alarm whenever a different event occurs.
  • Your mydlink Home
    mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter.
  • Set up, control, monitor and protect your home
    The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink home devices.
mydlink Home Siren - siren
Siren
Wireless - Z-Wave
Supported Host Device OS
iOS, Android
11 cm x 11 cm x 1.9 cm
Siren
Wireless - Z-Wave
iOS, Android
Push notification
Encryption Algorithm
128-bit AES
FCC
11 cm
11 cm
1.9 cm
125 g
-10 °C
20 - 90% (non-condensing)
Type: Siren
Brand: D-Link
Price Range Ex VAT: 0 - 50
