The mydlink Home Panoramic HD Camera allows you to monitor more of your home with a single camera. Forget pan, forget tilt, see everything instantly in full color high definition 720p with sound. The integrated microSD card slot1 allows you to record videos directly onto the camera when motion or sound is detected, without the need of a computer. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
- mydlink Home Panoramic HD Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 9.58 cm x 9.58 cm x 13.75 cm
- 165 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/2.7"
- Minimum Illumination
- 0.5 lux - colour , 0.1 lux - B&W , 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 1.72 mm
- Focus Adjustment
- (min distance 50 cm)
- Lens Iris
- F/2.0
- IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
- Voltage
- DC 5 V
- Date/time stamp, Motion Detection Technology, sound activated recording, password protection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wireless
- 9.58 cm
- 9.58 cm
- 13.75 cm
- 165 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Digital Zoom
- 8
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 720 x 480, 640 x 360
- Frame Rate (max)
Image Sensor
- CMOS 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 1.72 mm
- Lens Iris
- F/2.0
- Min Focus Distance
- 50 cm
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 120
- Network Interface
- Supported Memory Cards
- microSD Card, microSDHC Card
- FCC Class B certified, C-Tick, ICES, LVD
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external 4.8 Watt
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
