D-Link Multifunction Print Server 2 USB 1 Parallel Port
Quicklinx: 6KVWWS00 Mfr#: DPR-1061/B
The DPR-1061 Multifunction Print Server is a versatile multi-port print server ideal for home office, school or business use. Providing one parallel and two USB ports for printer connections, this device gives users the option of adding multiple printers, multifunction printers, or scanners to the network.
The DPR-1061 provides security by allowing the administrator to configure user access right to network printers and equipment. It supports a wide range of network OS including: Windows 95/98/ME/NT 4.0/2000/XP/Vista/7, Apple MacOS with AppleTalk, Linux, Solaris, SCO Unix, IBM AIX and NetWare 5.x native ND S.
The DPR-1061 supports the Internet Printing Protocol (IPP), enabling remote users to output files to their office printer even when they are off site. HP PJL protocol is also supported for bi-directional network printer communication, providing network administrators with critical information about the network printer.
The DPR-1061 includes D-Link's Click'n Connect software (DCC). This intuitive wizard is run directly from the product CD-ROM. In a few simple steps, it takes you through setting the Print Server up and configuring the attached printers (15 languages supported).
D-Link DPR-1061 - print server - USB/parallel - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB/parallel
Ports
10/100 Ethernet
19.3 cm x 11.8 cm x 3.1 cm
292 g
United Kingdom, Ireland
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP, NetBEUI/NetBIOS
IEEE 802.3
Print server
External
USB/parallel
Ports
10/100 Ethernet
Wired
Ethernet, Fast Ethernet
Remote Management Protocol
IPP
Status Indicators
Power, link/activity
DHCP server
IEEE 802.3
1 x 100Base-TX - RJ-45
1 x parallel - IEEE 1284 (EPP/ECP) - 36 PIN Centronics , 2 x USB
CSA, C-Tick, IC, FCC
Power adapter - external
19.3 cm
11.8 cm
3.1 cm
292 g
50 °C
5 - 95%
6KVW C2G 2m USB 2.0 A/B Cable - Black In Stock £4.03
