The D-Link DKVM-4U KVM switch allows you to control up to 4 PCs using only one monitor, keyboard and mouse. The monitor and the two input devices are connected directly to this KVM switch and not to the client computers. The DKVM-4U is also a cost effective solution for control of several servers in a computer room, allowing an engineer to handily manipulate all connected computers from a single monitor, keyboard and mouse.
Each KVM cable set includes a video cable for PC's VGA connector, and a single USB 2.0 cable for the PC's USB port. From the KVM switch box, you can connect to 2 USB devices: a USB keyboard and a USB mouse. 2 sets of KVM cables are provided for ready connection to 2 computers, the remaining KVM cables are optional.
You can switch quickly between the individual client computers by pushing a button on the DKVM-4U or by pressing the hot keys on your keyboard. The KVM switch confirms the switchover with an acoustic signal, and has LEDs indicating which PC is currently being served by the console. All connected PCs are automatically scanned every 10 seconds, so your monitor, keyboard and mouse are updated whenever you switch to a selected PC. CAPS LOCK, NUM LOCK and SCROLL LOCK key's status for each computer is automatically recalled. The DKVM-4U guarantees that the client PC does not crash when it is disconnected from KVM switch box.
The DKVM-4U is capable of supporting the most demanding resolutions (VGA, SVGA and Multisync monitors) of up to 2048 x 1536 at 75Hz refresh rate (bandwidth up to 400MHz) without any noticeable degradation in image quality.
USB KVM switch for 4 PCs
The D-Link DKVM-4U KVM switch is a handy device that allows you to control up to 4 PCs using only one monitor, keyboard and mouse. The monitor and the two input devices are connected directly to this KVM switch and not to the client computers. For office users with a need for several PCs, this KVM switch box eliminates the need for several monitors, keyboards and mice, saving the money and desktop space. The DKVM-4U is also a cost-effective solution for control of several servers in a computer room, allowing an engineer to handily manipulate all connected computers from a single monitor, keyboard and mouse. -
Save money and space
The DKVM-4U allows you to control up to 4 computers from a single keyboard, monitor and mouse, so you don't have to purchase a monitor, keyboard and mouse for each PC. Your desktop will also look less chaotic. Your KVM switch can be placed underneath your desk, with 4 sets to KVM cables connecting from this switch box to 4 computers. From the KVM switch box, you can connect to 2 USB devices. -
Easy control
You can switch quickly between the individual client computers by pushing a button on the DKVM-4U or by pressing the hot keys on your keyboard. The KVM switch confirms the switchover with an acoustic signal, and has LEDs indicating which PC is currently being served by the console. All connected PCs are automatically scanned every 10 seconds, so your monitor, keyboard and mouse are updated whenever you switch to a selected PC. -
High monitor resolution support
The DKVM-4U is capable of supporting very demanding resolutions (VGA, SVGA and Multisync monitors) of up to 2048x1536 at 75 Hz refresh rate (bandwidth up to 400 MHz) without any noticeable degradation in image quality.
- D-Link DKVM 4U - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 17.8 cm x 10.5 cm x 3.1 cm
- 275 g
- System Requirements
- Microsoft Windows NT, Red Hat Linux, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 2003
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536 @ 75 Hz
- Max Video Bandwidth
- 400 MHz
- 4 x VGA HD-15 , 4 x keyboard (USB) / mouse (USB) Type B , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Cables Included
- 2 x VGA cable - 1.8 m , 2 x USB cable - 1.8 m
- FCC Class B certified, C-Tick
- OS Required
- 17.8 cm
- 10.5 cm
- 3.1 cm
- 275 g
