The DNR-2020-04P JustConnect 16-Channel PoE Network Video Recorder is an all-in-one network video recorder (NVR) that can record video from up to 16 network cameras to its dual HDD storage. With the integrated HDMI/VGA display output and USB port, users can view, control and configure the DNR-2020-04P without the need to turn on their PC.
Enhanced connectivity
With a variety of ports including alarm inputs and outputs, audio in/out, USB 2.0 and 3.0, and HDMI and VGA video outputs, the DNR-2020-04P JustConnect offers a wide range of connectivity options for a variety of devices. -
Robust video storage
Supporting up to 16 TB of storage across two Serial ATA HDDs, this standalone NVR ensures your video data is securely stored and easily accessible. -
High-quality video compression
Featuring multiple compression formats such as H.264, MJPEG, and MPEG-4, the device optimizes storage space without compromising video quality. -
Comprehensive network support
Equipped with Ethernet 10Base-T/100Base-TX/1000Base-T interfaces and supporting a wide range of protocols, this NVR ensures seamless integration into any existing network infrastructure. -
Advanced security features
From motion detection to pan/tilt/zoom support and RAID 0 and 1 support, the DNR-2020-04P JustConnect is designed to provide a secure and efficient surveillance solution.
- D-Link DNR-2020-04P JustConnect - standalone NVR - 16 channels
- NVR - 16 channels - networked
- Frame Rate
- 480 fps
- Compression Format
- MJPEG, H.264, MPEG-4, G.711, G.726
- Image Resolution
- 1920x1080, 1280x720, 1024x768, 1280x1024
- Hard Drive(s) Supported
- Quantity: 2 - total capacity: 16 TB
- Voltage
- 100 - 240 V
- 30 cm x 22.5 cm x 6.3 cm
- 2.1 kg
- NVR
- Video Channels
- 16
- Image Resolution
- Package Content
- External power adapter, software
- Cables Included
- Network cable - 1 pcs.
- Software Included (Y)
- Drivers & Utilities
- FCC, RoHS
Security DVR
- Frame Rate (Record)
- 480 fps
- Record Events
- Continuous, event, manual, motion detection, scheduled
- Networked
- Motion detection, RAID 0 support, RAID 1 support, Pan/Tilt/Zoom support
Hard Drive
- Quantity Supported
- 2
- Interface
- Serial ATA
- Supported Max Total Capacity
- 16 TB
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- IPv4, ARP, TCP/IP, UDP/IP, ICMP, DHCP, NTP, DNS, DDNS, SMTP, HTTP, FTP, RTP, RTSP, RTCP, UPnP, CoS, QOS, DSCP, HTTPS, Samba, Bonjour, SNMP 1, SNMP 2c, SNMP 3, PPPoE
- Power over Ethernet (PoE), ONVIF support
- Video Input Ports
- RJ-45 x 4
- Video Output Ports
- VGA x 1, HDMI x 1
- Audio Input Ports
- Mini-phone 3.5 mm x 1
- Audio Output Ports
- Alarm Ports
- Alarm input x 4, alarm output x 1
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0, USB 3.0 x 1
- Voltage
- 100 - 240 V
- Frequency
- 50/60 Hz
- Power Consumption
- 90 watt
- 30 cm
- 22.5 cm
- 6.3 cm
- 2.1 kg
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
D-Link JustConnect 16-Channel Multifunctional Network Video Recorde
