For the core of your network, the DIS-700G features user management interfaces and provides diagnostics, security and controls to shape your managed network needs.
Strong build
The tough housing has been created to keep your network protected and reliably rugged. -
Fanless design
With no moving parts inside to reduce downtime and maintenance call outs, the rugged housing has been optimized for the transfer of heat. -
Withstands extreme temperatures
Operates effortlessly in industrial and harsh environments in a wide range of temperatures.
- D-Link DIS 700G-28XS - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L2+ - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x Gigabit SFP + 4 x 10 Gigabit SFP+
- Capacity
- VLANs supported: 2048 , IGMP multicast groups: up to 512 , Queues per port: 8
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, SSH, CLI, NTP
- Flow control, IGMP snooping, Syslog support, traffic shaping, store and forward, Broadcast Storm Control, High Availability, Multicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, ACL support, MVR, SPQ, ToS, DSCP support, IGMP querier, VLAN Double Tagging (Q-in-Q), WRR, Advanced QoS, Flooding Storm Control
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v
- Power
- AC 120/230 V (50 - 60 Hz)
- 44 cm x 4.4 cm x 31.85 cm
- 4.5 kg
- 5-year warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- Authentication Method
- RADIUS
- Status Indicators
- Power, link/speed
- 24 x 1000Base-X SFP , 4 x 10GBase-X SFP+
- Power Device
- Internal power supply
- Max Supported Qty
- 1
- Voltage Required
- 35 Watt
- MTBF
- 25 years
- UL, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, CISPR 22, FCC, EN 61000-6-2, RoHS, EN 61000-6-4, WEEE, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, UL 61010-1, IP30, EN 55022 Class A
- 44 cm
- 4.4 cm
- 31.85 cm
- 4.5 kg
- Limited warranty - 5 years
- -10 °C
- 65 °C
- 5 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Humidity Range Storage
- 5 - 95%
