D-Link Industrial Layer 2+ Gigabit Managed Switch with 24 SFP Ports
Quicklinx: J7M7WS00 Mfr#: DIS-700G-28XS
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£3,101.64 ex VAT
£3,721.96 inc VAT
For the core of your network, the DIS-700G features user management interfaces and provides diagnostics, security and controls to shape your managed network needs.
  • Strong build
    The tough housing has been created to keep your network protected and reliably rugged.
  • Fanless design
    With no moving parts inside to reduce downtime and maintenance call outs, the rugged housing has been optimized for the transfer of heat.
  • Withstands extreme temperatures
    Operates effortlessly in industrial and harsh environments in a wide range of temperatures.
D-Link DIS 700G-28XS - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 4 x 10 Gigabit SFP+
VLANs supported: 2048 , IGMP multicast groups: up to 512 , Queues per port: 8
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMP, IGMPv2, IGMPv3
Remote Management Protocol
CLI, SNMP 1, SNMP 2c, SNMP 3, Telnet, HTTPS, SSH, TFTP, NTP
High Availability, Advanced QoS, ACL support, store and forward, STP support, MSTP support, RSTP support, flow control, VLAN Double Tagging (Q-in-Q), MVR, IGMP querier, IGMP snooping, DSCP support, ToS, SPQ, WRR, traffic shaping, Broadcast Storm Control, Multicast Storm Control, Flooding Storm Control, Syslog support, SNTP support
IEEE 802.1D, IEEE 802.1w, IEEE 802.1s, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1Q, IEEE 802.1v, IEEE 802.1ad, IEEE 802.1x
AC 120/230 V (50 - 60 Hz)
44 cm x 4.4 cm x 31.85 cm
4.5 kg
5-year warranty
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Authentication Method
RADIUS
Status Indicators
Power, link/speed
24 x 1000Base-X SFP , 4 x 10GBase-X SFP+
Internal power supply
Max Supported Qty
1
35 watt
MTBF
25 years
IP30, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, UL, FCC, UL 61010-1, EN 61000-6-2, EN 61000-6-4, CISPR 22, EN 55022 Class A, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, RoHS, WEEE
44 cm
4.4 cm
31.85 cm
4.5 kg
Limited warranty - 5 years
-10 °C
65 °C
5 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Humidity Range Storage
5 - 95%
Ports: 24
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £1500+
