D-Link EXO AC2600 Smart Mesh Dual Band Wi-Fi Router
Quicklinx: F9DRWS00 Mfr#: DIR-2660
  • IEEE 802.11n
£105.28 ex VAT
£126.33 inc VAT
Need super-fast Wi-Fi for your wire-free, all-streaming house? With a powerful processor, the AC2600 Smart Mesh Wi-Fi Router packs in enough of processing power to handle every networking task you throw at it. It's a powerful, intelligent home router with built-in McAfee protection for every device on your network. It supercharges your mesh network with D-Link's Wi-Fi Mesh technology so you can grow your mesh network by adding compatible D-Link routers and extenders. It even integrates voice assistant compatibility for Amazon Alexa and Google Assistant so you can control your network with voice commands. So stop settling for just a Wi-Fi signal - you deserve so much more.
  • Handle more with a high-power processor
    With the DIR-2660, you're not only enjoying buffer-free gaming and lightning fast surfing, you're also enjoying features such as an integrated mesh for a higher coverage network, an automatically optimizing QoS with a built-in speed test, an automatic firmware update system that ensures an outstanding protection and the advanced features, and compatibility with voice assistants. All this is possible with the router's high-power processor. The router is no longer just a networking device - it is a powerful, intelligent home gateway with processing power to boot.
  • Extend and adapt your high-speed wireless AC network
    D-Link's Wi-Fi Mesh is a scalable solution that allows you to easily increase the coverage of your home or office wireless AC network. Expand your Wi-Fi coverage by adding compatible D-Link access points. Mix and match suitable D-Link devices according to your budget and preferences to fit any floorplan. Setup is effortless; configuration of multiple access points can be done in minutes as settings can be passed on to other access points once the first access point is configured.
  • Security for your network with McAfee protection
    Kick security up a notch with McAfee protection for your network. Keep your kids safe online with age-based profiles and the ability to pause the Internet when you need to. All this is part of the comprehensive parental controls offered by the McAfee Secure Home Platform. With the McAfee Secure Home Platform you can also take control of your devices and be the first to know and respond to potentially threatening activity on your network, such as devices trying to connect to malicious addresses, or unidentified devices joining your network. When you are away from home you can also deny any new devices from connecting to your network. The McAfee Secure Home Platform works with Amazon Alexa to give you another way to command and monitor your home network using your voice. You can scan your network, block devices, and get up to speed on your network notifications - all without lifting a finger.
  • Always up-to-date with the advanced features
    Tired of having to visit the website or manually going to the router's UI every so often to check for the modern firmware? The DIR-2660 will automatically check daily for updates to make sure that the device always has the advanced features and incredibly secure firmware, and will install the update silently in the background. For an extra peace of mind, in the event of failure during the firmware update, the router will store a backup system image in the memory before proceeding with the update.
  • Easy to set up and manage
    Sharing your Internet connection doesn't have to be a complicated process; just download the D-Link Wi-Fi app for your mobile device and follow the on-screen step-by-step instructions to set up your DIR-2660. You also have the possibility to use a web browser to access the setup wizard and to manage your router. Support for industry-standard Wi-Fi Protected Setup (WPS) lets you create encrypted connections to new devices by pressing a button. In addition, the access control features allow you to restrict access to your network, giving you greater control over your network users.
  • Enhanced Quality of Service features
    The built-in Quality of Service (QoS) engine allows you to prioritize important traffic to ensure that your favorite applications are receiving optimal bandwidth. Also included as part of the QoS feature is the speed test, which not only allows you to check the current upload and download speed of your Internet connection, but also gives you the possibility of automatically configuring your router to optimize your traffic according to speed test results.
D-Link DIR-2660 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2600 Mbps
Intelligent Assistant
Google Assistant, Alexa
NAT support, parental control, firmware upgradable, QoS, WPS, 4x4 MU-MIMO technology
IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
AC 100 - 240 V (50/60 Hz)
22.292 cm x 17.658 cm x 6.5 cm
610 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2600 Mbps
Encryption Algorithm
WPA, WPA2
Wi-Fi Rating
AC2600
IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IC, FCC
880 MHz
RAM
256 MB
Flash Memory
128 MB
Status Indicators
Power, wireless, USB, Internet
Internet of Things (IoT)
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External
Antenna Qty
4
External power adapter
Software Included
McAfee LiveSafe
22.292 cm
17.658 cm
6.5 cm
610 g
10 - 90% (non-condensing)
Type: Wireless router
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11ac
Speed: 2600Mbps
Brand: D-Link
