D-Link EXO AC1900 Smart Mesh Dual Band Wi-Fi Router
Customer rating: 5.0* (Write a review)
Quicklinx: F9DQWS00 Mfr#: DIR-1960
  • IEEE 802.11n
£97.76 ex VAT
£117.31 inc VAT
The EXO AC1900 Smart Mesh Wi-Fi Router brings hyper-fast AC1900 Wi-Fi, powerful McAfee protection, voice-based smart home Wi-Fi control and radical Wi-Fi mesh technology to your smart home. Because you know you deserve more than just a Wi-Fi signal.
  • More powerful
    Need fast Wi-Fi for your no-cable-all-streaming home? The EXO AC1900 Smart Mesh Wi-Fi Router packs a powerful 880 MHz dual-core processer to handle buffer-free gaming and lightning-fast surfing with ease.
  • Multiple connections for multiple devices
    EXO features MU-MIMO(Multi-User MIMO) technology, allowing multiple devices to receive data simultaneously. Compatible devices no longer have to queue up for Wi-Fi because each gets its own dedicated, super-fast Wi-Fi stream.
D-Link DIR-1960 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1900 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, FTP, DHCP, IPv6
Routing Protocol
Static IP routing, static IPv6 routing
Intelligent Assistant
Google Assistant, Alexa
NAT support, VPN support, parental control, firmware upgradable, QoS, WPS, Samba support, Guest Zone support, 4x4 MU-MIMO technology
IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
AC 100 - 240 V (50/60 Hz)
22.292 cm x 17.658 cm x 6.5 cm
593 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1900 Mbps
Routing Protocol
Encryption Algorithm
WPA, WPA2
Wi-Fi Rating
AC1900
IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IC, FCC
880 MHz
RAM
256 MB
Flash Memory
128 MB
Status Indicators
Power, wireless, USB, Internet
Internet of Things (IoT)
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External
Antenna Qty
4
External power adapter
Software Included
McAfee LiveSafe
22.292 cm
17.658 cm
6.5 cm
593 g
10 - 90% (non-condensing)
Customer reviews
Write a review for the D-Link EXO AC1900 Smart Mesh Dual Band Wi-Fi Router here!
Good
Reviewed by Peter. Review Posted 09/04/2024
Good
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Wireless router
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 1900Mbps
Brand: D-Link
