The EXO AC1900 Smart Mesh Wi-Fi Router brings hyper-fast AC1900 Wi-Fi, powerful McAfee protection, voice-based smart home Wi-Fi control and radical Wi-Fi mesh technology to your smart home. Because you know you deserve more than just a Wi-Fi signal.
More powerful
Need fast Wi-Fi for your no-cable-all-streaming home? The EXO AC1900 Smart Mesh Wi-Fi Router packs a powerful 880 MHz dual-core processer to handle buffer-free gaming and lightning-fast surfing with ease. -
Multiple connections for multiple devices
EXO features MU-MIMO(Multi-User MIMO) technology, allowing multiple devices to receive data simultaneously. Compatible devices no longer have to queue up for Wi-Fi because each gets its own dedicated, super-fast Wi-Fi stream.
- D-Link DIR-1960 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1900 Mbps
- PPTP, L2TP, PPPoE, FTP, DHCP, IPv6
- Routing Protocol
- Static IP routing, static IPv6 routing
- Intelligent Assistant
- Google Assistant, Alexa
- NAT support, VPN support, parental control, firmware upgradable, QoS, WPS, Samba support, Guest Zone support, 4x4 MU-MIMO technology
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 100 - 240 V (50/60 Hz)
- 22.292 cm x 17.658 cm x 6.5 cm
- 593 g
- System Requirements
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1900 Mbps
- Routing Protocol
- Encryption Algorithm
- WPA, WPA2
- Wi-Fi Rating
- AC1900
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IC, FCC
- Processor
- 880 MHz
- RAM
- 256 MB
- Flash Memory
- 128 MB
- Status Indicators
- Power, wireless, USB, Internet
Internet of Things (IoT)
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- Software Included
- McAfee LiveSafe
- OS Required
- 22.292 cm
- 17.658 cm
- 6.5 cm
- 593 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Customer reviews
Write a review for the D-Link EXO AC1900 Smart Mesh Dual Band Wi-Fi Router here!
Good
Reviewed by Peter. Review Posted 09/04/2024
Good
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
