D-Link Enhanced Wireless N Day/Night Home Network Camera
GREAT SPEC WIRELESS DAY/NIGHT NETWORK CAMERA - WAS £77.16!
Quicklinx: 7TMZWS00 Mfr#: DCS-942L/B
The DCS-942L Enhanced Wi-Fi Day/Night Camera is a complete surveillance solution for your home or small office. The built-in night vision and PIR motion sensor give you 24 hour surveillance with motion detection, and you can record snapshots and video directly to the included microSD card1. It's mydlink enabled too, so you can check on your camera anytime, anywhere from any PC, tablet, or mobile phone.
Peace Of Mind With 24/7 Monitoring Of Any Environment
The DCS-942L gives you clear video in any environment. It uses a moving IR cut filter to give you the best possible picture at any time of day; during the daytime, the IR cut filter helps give you a crisp colour image and at night, the IR cut filter moves out of the way and the infrared LEDs turn on for a clear video even in complete darkness. Now you can keep watch over what's important, day or night.
Highly Versatile Surveillance
The Enhanced Wi-Fi Day/Night Camera is a complete surveillance solution that can run independently, even without a PC. The built-in PIR motion sensor accurately detects nearby motion, and can send you e-mail notifications with snapshots or video clips whenever movement is detected. The DCS-942L can also detect loud sounds such as glass breaking or a baby crying, and record video of the event directly to an inserted microSD card. You can even connect a speaker to the camera for two-way communication, making it great for nurseries or entryways.
mydlink™: the easiest way to setup up your camera and monitor your home
Connecting a camera on your network and accessing it has traditionally required complex configuration. mydlink™ makes it easy to access your camera from wherever you are, whenever it's convenient for you. Using the free mydlink™ Lite app for iOS and Android smartphones and tablets, you can connect and setup your mydlink™ camera without turning on a computer. A step-by-step guide has your camera up and running in a matter of minutes. Through the mydlink™ Lite app, you can set up a free mydlink™ account which allows you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink™ account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink™ Lite app for your iOS, Android or Windows Phone device and you can quickly and easily view your camera feed from anywhere with a wireless or 3G/4G LTE connection. You can even access videos recorded onto the included SD card. Thanks to this app, you can monitor on-the-go even if you don't have access to a computer.
If you have a mydlink™-enabled Cloud Router, setting up and configuring your DCS-942L is a snap, thanks to Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable - the camera will automatically be added to your account.
Create a Comprehensive Surveillance System
Included with the DCS-942L is the D-ViewCam software, which adds enhanced features and functionality that helps you create a full surveillance system. D-ViewCam enables centralised management of multiple network cameras, supporting up to 32 network cameras and up to 64 users. With a dedicated computer it offers digital monitoring and recording with a wide array of features, including scheduled, motion and manual recording options for individual needs.
1 16 GB microSD card included. Supports card capacities up to 32 GB.
  • Enhanced visibility
    Equipped with Intelligent IR Technology and a minimum illumination of 1 lux, this camera ensures clear visibility in low-light conditions, making it perfect for round-the-clock surveillance.
  • Versatile connectivity
    With support for Ethernet and Wi-Fi, including IEEE 802.11b/g/n standards, this camera offers flexible installation options and easy integration into your existing network.
  • High-quality imaging
    Featuring a CMOS optical sensor and digital zoom up to 4x, the camera captures detailed video footage at resolutions up to 640 x 480 pixels, ensuring critical moments are never missed.
  • Two-way audio support
    Thanks to its built-in microphone and two-way audio capability, this camera allows for interactive communication, enhancing security protocols and providing peace of mind.
  • Easy setup
    Wi-Fi Protected Setup (WPS) feature simplifies the process of connecting to your network, ensuring a hassle-free installation without compromising security.
D-Link DCS 942L mydlink-enabled Enhanced Wireless N Day/Night Home Network Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability, built-in microphone
6 cm x 2.7 cm x 9.6 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/5" - 0.3 MP
Minimum Illumination
1 lux - colour - F2.8
Lens Iris
F/2.8
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 5 V
Intelligent IR Technology, Wi-Fi Protected Setup (WPS)
1-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
6 cm
2.7 cm
9.6 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
640 x 480
Digital Zoom
4
Video Capture
160 x 120 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 30 fps
Supported Image Formats
JPEG
RAM
128 MB
Flash Memory
16 MB
Image Sensor
0.3 MP CMOS 1/5"
Lens Construction
Lens Iris
F/2.8
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE, 3GPP/ISMA
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
1 x network cable - external
FCC Class B certified, C-Tick, IC
Power Requirements
DC 5 V
Power adapter - external AC 120/230 V (50/60 Hz) 2 Watt
Software Included
D-ViewCam
Microsoft Windows Vista / XP / 7
System Requirements Details
1.3 GHz - RAM 128 MB
Limited warranty - 1 year
Relative Humidity (operating)
7TMZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.09
Resources
The following resources are available for the D-Link Enhanced Wireless N Day/Night Home Network Camera
