The D-Link EAGLE PRO AI M32-3 Wi-Fi system enhances connectivity in your home or office. Equipped with Wi-Fi 6 technology, it supports faster speeds and more devices simultaneously. With a total data transfer rate of up to 3.2 Gbps and dual-band support, this system ensures uninterrupted streaming, gaming, and browsing.
Security is a top priority, and the D-Link EAGLE PRO AI M32-3 meets this need with advanced encryption standards, including WPA3, to keep your network secure. The system also supports voice control through Alexa and Google Assistant, integrating seamlessly into any smart home ecosystem.
Designed for extensive coverage, the three routers work together to cover up to 740 sq.m, ensuring reliable Wi-Fi throughout your space. Whether in a large home or a multi-story office, the D-Link EAGLE PRO AI M32-3 provides a stable and fast Internet connection.
- D-Link EAGLE PRO AI M32-3 - Wi-Fi system - Wi-Fi 6 - desktop
- Wi-Fi system - mesh
- Enclosure Type
- Desktop
- Wi-Fi System Components
- 3 routers
- Wi-Fi System Coverage
- Up to 740 sq.m
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 3.2 Gbps
- Performance
- Maximum data rate (2.4 GHz): 800 Mbps , Maximum data rate (5 GHz): 2402 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- Static IP routing
- Intelligent Assistant
- Google Assistant, Alexa
- Remote Management Protocol
- HTTP
- QoS, WPS, dynamic IP mode, MU-MIMO technology, guest access, TWT, BSS Coloring
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
- 16.461 cm x 7.107 cm x 18.565 cm
- 486 g
- 2-year warranty
- Wi-Fi system - mesh - 2-port switch (integrated)
- 3 routers
- Up to 740 sq.m
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 3.2 Gbps
- Performance
- PPTP, L2TP, PPPoE
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- WPA, WPS, WPA3, WPA3-Personal, WPA2-Personal
- Wi-Fi Rating
- AX3200
- Mesh Networking
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax, FCC, IEC 62443-4-1
- Status Indicators
- Status
Line Properties
- Line Coding Format
- 1024 QAM, OFDMA
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 2 x 1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- Power Device
- External power adapter
- 15.51 Watt
- 16.461 cm
- 7.107 cm
- 18.565 cm
- 486 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
