Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
D-Link Eagle Pro AI AX3200 Mesh WiFi System (2-pack)
Quicklinx: H1MKWS00 Mfr#: M32-2
£113.44 ex VAT
£136.12 inc VAT
Discover the power of advanced Wi-Fi with the D-Link EAGLE PRO AI M32-2 Wi-Fi system. Designed to deliver reliable connectivity, this system leverages Wi-Fi 6 technology to provide fast speeds of up to 3.2 Gbps, ensuring your devices always have the bandwidth they need. With coverage of up to 510 sq.m, it eliminates dead zones in your home or office, making it perfect for streaming, gaming, and downloading across multiple devices.
The D-Link EAGLE PRO AI M32-2 doesn't just offer speed and coverage; it also prioritizes your security. Featuring advanced WPA3 encryption, it safeguards your network against unauthorized access, giving you peace of mind. Additionally, its compatibility with Alexa and Google Assistant allows for seamless integration into your smart home ecosystem, enabling voice control over your network settings.
Whether you're working from home, streaming your favorite shows, or connecting smart home devices, the D-Link EAGLE PRO AI M32-2 is designed to meet the demands of modern digital life. Its advanced features like MU-MIMO and OFDMA technology ensure efficient data transmission, while the system's easy setup and management make it an ideal choice for anyone looking to upgrade their Wi-Fi experience.
  • Enhanced connectivity
    With dual-band support offering 2.4 GHz and 5 GHz frequencies, the D-Link EAGLE PRO AI M32-2 ensures a more reliable connection. The device's ability to operate on Wi-Fi 6 technology enhances your Internet experience by providing faster speeds and greater efficiency across your devices.
  • Comprehensive coverage
    Designed to cover up to 510 sq.m, this Wi-Fi system includes two routers that work together to eliminate dead zones in your home or office, ensuring seamless connectivity in every corner.
  • Advanced security
    The D-Link EAGLE PRO AI M32-2 comes equipped with multiple encryption algorithms including WPA3, offering advanced security protocols to keep your network safe from intruders.
  • Smart home ready
    With compatibility for both Alexa and Google Assistant, this Wi-Fi system integrates seamlessly into your smart home setup, allowing for easy voice control over your network.
  • Efficient data handling
    Featuring technologies like MU-MIMO and OFDMA, the device efficiently manages data across multiple devices simultaneously, reducing wait times and improving overall network capacity.
D-Link EAGLE PRO AI M32-2 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
Wi-Fi System Coverage
Up to 510 sq.m
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
Performance
Maximum data rate (2.4 GHz): 800 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
Intelligent Assistant
Google Assistant, Alexa
Remote Management Protocol
HTTP
QoS, WPS, dynamic IP mode, MU-MIMO technology, guest access, TWT, BSS Coloring
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
16.461 cm x 7.107 cm x 18.565 cm
486 g
Wi-Fi system - mesh - 2-port switch (integrated)
2 routers
Up to 510 sq.m
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
Performance
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
WPA, WPS, WPA3, WPA3-Personal, WPA2-Personal
Wi-Fi Rating
AX3200
Mesh Networking
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax, FCC, IEC 62443-4-1
Status Indicators
Status
Line Properties
Line Coding Format
1024 QAM, OFDMA
Internet of Things (IoT)
WAN: 1 x 1000Base-T - RJ-45 , LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
Directivity
Omni-directional
External power adapter
15.51 Watt
16.461 cm
7.107 cm
18.565 cm
486 g
10 - 90% (non-condensing)
Brand: D-Link
