Discover the power of advanced Wi-Fi with the D-Link EAGLE PRO AI M32-2 Wi-Fi system. Designed to deliver reliable connectivity, this system leverages Wi-Fi 6 technology to provide fast speeds of up to 3.2 Gbps, ensuring your devices always have the bandwidth they need. With coverage of up to 510 sq.m, it eliminates dead zones in your home or office, making it perfect for streaming, gaming, and downloading across multiple devices.
The D-Link EAGLE PRO AI M32-2 doesn't just offer speed and coverage; it also prioritizes your security. Featuring advanced WPA3 encryption, it safeguards your network against unauthorized access, giving you peace of mind. Additionally, its compatibility with Alexa and Google Assistant allows for seamless integration into your smart home ecosystem, enabling voice control over your network settings.
Whether you're working from home, streaming your favorite shows, or connecting smart home devices, the D-Link EAGLE PRO AI M32-2 is designed to meet the demands of modern digital life. Its advanced features like MU-MIMO and OFDMA technology ensure efficient data transmission, while the system's easy setup and management make it an ideal choice for anyone looking to upgrade their Wi-Fi experience.
Enhanced connectivity
With dual-band support offering 2.4 GHz and 5 GHz frequencies, the D-Link EAGLE PRO AI M32-2 ensures a more reliable connection. The device's ability to operate on Wi-Fi 6 technology enhances your Internet experience by providing faster speeds and greater efficiency across your devices. -
Comprehensive coverage
Designed to cover up to 510 sq.m, this Wi-Fi system includes two routers that work together to eliminate dead zones in your home or office, ensuring seamless connectivity in every corner. -
Advanced security
The D-Link EAGLE PRO AI M32-2 comes equipped with multiple encryption algorithms including WPA3, offering advanced security protocols to keep your network safe from intruders. -
Smart home ready
With compatibility for both Alexa and Google Assistant, this Wi-Fi system integrates seamlessly into your smart home setup, allowing for easy voice control over your network. -
Efficient data handling
Featuring technologies like MU-MIMO and OFDMA, the device efficiently manages data across multiple devices simultaneously, reducing wait times and improving overall network capacity.
- D-Link EAGLE PRO AI M32-2 - Wi-Fi system - Wi-Fi 6 - desktop
- Wi-Fi system - mesh
- Enclosure Type
- Desktop
- Wi-Fi System Components
- 2 routers
- Wi-Fi System Coverage
- Up to 510 sq.m
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 3.2 Gbps
- Performance
- Maximum data rate (2.4 GHz): 800 Mbps ¦ Maximum data rate (5 GHz): 2402 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- Static IP routing
- Intelligent Assistant
- Google Assistant, Alexa
- Remote Management Protocol
- HTTP
- QoS, WPS, dynamic IP mode, MU-MIMO technology, guest access, TWT, BSS Coloring
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
- 16.461 cm x 7.107 cm x 18.565 cm
- 486 g
- 2-year warranty
- Wi-Fi system - mesh - 2-port switch (integrated)
- 2 routers
- Up to 510 sq.m
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 3.2 Gbps
- Performance
- PPTP, L2TP, PPPoE
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- WPA, WPS, WPA3, WPA3-Personal, WPA2-Personal
- Wi-Fi Rating
- AX3200
- Mesh Networking
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax, FCC, IEC 62443-4-1
- Status Indicators
- Status
Line Properties
- Line Coding Format
- 1024 QAM, OFDMA
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 2 x 1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- Power Device
- External power adapter
- 15.51 watt
- 16.461 cm
- 7.107 cm
- 18.565 cm
- 486 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
