D-Link DWR-933 - Mobile hotspot - 4G LTE - 802.11ac
Quicklinx: FXM4WS00 Mfr#: DWR-933
Type: Mobile hotspot
Enclosure: External
Interface: [N/A]
Compatibility: [N/A]
£64.13 ex VAT
£76.95 inc VAT
The DWR-933 4G LTE Mobile Router is a high-speed broadband wireless WAN (WWAN) to Wi-Fi mobile hotspot that creates fast Wi-Fi networks anywhere you need one.
  • Lightning-fast 4G LTE & Wi-Fi in one router
    The DWR-933 4G LTE Mobile Router is a high-speed broadband wireless WAN (WWAN) to Wi-Fi mobile hotspot. It uses a mobile Internet connection to give you a simple and fast Wi-Fi network anywhere you need one. The convenient size and all-day battery let you stay connected anywhere, on the go.
  • Blazing speeds for mobile needs
    The 4G LTE Mobile Router uses 4G/LTE-Advanced Category 6 cellular technology to share your 4G LTE Internet connection at blazing-fast speeds of up to 300 Mbps. Send large emails in a cafe while your friend streams their favorite shows, or share your connection at the airport so you and your coworkers can video conference with customers while waiting for your ?ight.
  • A connection that stays with you
    Simply insert your data-enabled SIM card into the on-board slot to keep your friends and family connected. The 4G LTE Mobile Router creates a Wi-Fi network in your pocket that's ideal for business trips, sharing Internet during a meeting, or for travel where mobility is a must.
D-Link DWR-933 - mobile hotspot - 4G LTE
Mobile hotspot
External
Mobile Communication Protocol
GSM, UMTS, WCDMA, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
Mobile Band
GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / LTE B38
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac - 300 Mbps
3000 mAh
9.8 cm x 7.1 cm x 1.88 cm
120 g
Mobile hotspot
External
Built-in Devices
0.96-inch OLED
Modem
Wireless
Mobile Band
Antenna
Internal
Wireless
Data Transfer Rate
300 Mbps
Firewall protection, NAT support, Wi-Fi Protected Setup (WPS), port forwarding, 2T2R MIMO technology, dual band, DMZ support
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
1 x micro-USB
SIM Card Supported
Micro-SIM x 1
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
BSMI, RoHS
Lithium Ion
3000 mAh
9.8 cm
7.1 cm
1.88 cm
120 g
10 - 90% (non-condensing)
Enclosure: External
Interface: [N/A]
Brand: D-Link
