The DWR-933 4G LTE Mobile Router is a high-speed broadband wireless WAN (WWAN) to Wi-Fi mobile hotspot that creates fast Wi-Fi networks anywhere you need one.
Lightning-fast 4G LTE & Wi-Fi in one router
The DWR-933 4G LTE Mobile Router is a high-speed broadband wireless WAN (WWAN) to Wi-Fi mobile hotspot. It uses a mobile Internet connection to give you a simple and fast Wi-Fi network anywhere you need one. The convenient size and all-day battery let you stay connected anywhere, on the go. -
Blazing speeds for mobile needs
The 4G LTE Mobile Router uses 4G/LTE-Advanced Category 6 cellular technology to share your 4G LTE Internet connection at blazing-fast speeds of up to 300 Mbps. Send large emails in a cafe while your friend streams their favorite shows, or share your connection at the airport so you and your coworkers can video conference with customers while waiting for your ?ight. -
A connection that stays with you
Simply insert your data-enabled SIM card into the on-board slot to keep your friends and family connected. The 4G LTE Mobile Router creates a Wi-Fi network in your pocket that's ideal for business trips, sharing Internet during a meeting, or for travel where mobility is a must.
- D-Link DWR-933 - mobile hotspot - 4G LTE
- Mobile hotspot
- Form Factor
- External
- Mobile Communication Protocol
- GSM, UMTS, WCDMA, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
- Mobile Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / LTE B38
- Networking
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac - 300 Mbps
- Battery
- 3000 mAh
- 9.8 cm x 7.1 cm x 1.88 cm
- 120 g
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- 0.96-inch OLED
Modem
- Connectivity Technology
- Wireless
- Mobile Band
- Antenna
- Internal
- Wireless
- Data Link Protocol
- Data Transfer Rate
- 300 Mbps
- Firewall protection, NAT support, Wi-Fi Protected Setup (WPS), port forwarding, 2T2R MIMO technology, dual band, DMZ support
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 1 x micro-USB
- SIM Card Supported
- Micro-SIM x 1
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- BSMI, RoHS
- Battery
- Lithium Ion
- Capacity
- 3000 mAh
- 9.8 cm
- 7.1 cm
- 1.88 cm
- 120 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
