D-Link DWR-932 Mobile Wi-Fi 4G Hotspot 150 Mbps
Quicklinx: 9T69WS00 Mfr#: DWR-932
Type: Mobile Hotspot
Connection Type: [N/A]
Standards: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speed: 150Mbps
Rackmount or External: External
  • IEEE 802.11n
More than 50 In Stock
£36.85 ex VAT
£44.22 inc VAT
D-Link's DWR-932 4G LTE Mobile Wi-Fi Hotspot 150 Mbps allows you to connect and share super-fast 4G LTE mobile Internet with download speeds of up to 150 Mbps, allowing you to stream music/videos, play online games, download and upload files on multiple devices from anywhere at higher speeds.
  • Share with others
    The portable size and battery powered enabled you to share your connection anywhere. Share a single mobile Internet connection with your friends or colleagues to send and receive e-mail, surf the Internet or make VoIP calls, on multiple devices, all at the same time.
  • Product highlights
    Connect your high-speed mobile broadband connection to multiple Wi-Fi devices such as smartphones, tablets and notebook computers. A built-in firewall protects against attacks over the Internet, and industry-standard WPA/WPA2 security prevents unauthorized access to your network. Small enough to fit in your pocket with high-capacity rechargeable battery, lets you work and play for longer on the go.
  • Connect anywhere
    Simply insert your data-enabled SIM card and share you Internet to let your family and friends stay connected. Ideal for business trips to share an Internet connection during a meeting or while traveling, allowing you to provide all your travel companions Internet access whether, they’re using a laptop or a mobile device.
D-Link DWR-932 - mobile hotspot - 4G LTE
Mobile hotspot
External
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSDPA, HSUPA, LTE
Mobile Band
GSM 850/900/1800/1900 / UMTS 2100
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 150 Mbps
2000 mAh - up to 5 hrs
Apple MacOS X 10.6 or later, Linux Kernel 2.6.x, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
7.3 cm x 7.3 cm x 1.5 cm
77 g
1.411 W/kg (head) , 1.411 W/kg (body) , 1.411 W/kg (limb)
Mobile hotspot
External
Built-in Devices
Display
Modem
Wireless
Mobile Band
Antenna
Internal
Wireless
Data Transfer Rate
150 Mbps
Firewall protection, NAT support, Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
1 x micro-USB
SIM Card Supported
Micro-SIM x 1
Encryption Algorithm
WPA-PSK, WPA2-PSK
Lithium Ion
7.3 cm
7.3 cm
1.5 cm
77 g
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 150Mbps
Brand: D-Link
