D-Link DWR-921 4G LTE Router
Quicklinx: 9662WS00 Mfr#: DWR-921/B
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11b, Ethernet, Fast Ethernet, IEEE 802.11n + 1 more
Speed: 150Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£136.36 ex VAT
£163.63 inc VAT
Product Highlights
  • 4G LTE mobile connectivity lets you take your broadband connection with you wherever you go
  • Create your personal high-speed Wireless N hotspot with speeds of up to 300 Mbps
  • Dual active firewalls and WPA/WPA2 wireless encryption ensure that your network stays secure
D-Link’s DWR-921 4G LTE Router allows you to access and share your 4G LTE or 3G mobile broadband connections. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your SIM/USIM card and share your 4G LTE or 3G Internet connection through a secure wireless network or any of the four Ethernet ports.The DWR-921 4G LTE Router is designed with constant connection in mind. Dual-band 4G LTE and 3G support allows automatic 3G connection if or when the 4G LTE signal strength becomes low, whereas the additional xDSL/FTTH Ethernet WAN option gives fail-safe connectivity if either your fixed line or mobile broadband fails.
Fast Mobile Internet
The 4G LTE Router lets you connect to your 4G LTE mobile connection with fast download speeds of up to 100 Mbps and upload speeds of up to 50 Mbps, giving you a fast and responsive Internet experience, allowing you to surf the web with ease and stream music and video without buffering.
Secure Wired and Wireless Connections
The DWR-921 utilises dual-active firewalls (SPI and NAT) to prevent potential unwanted intrusions from Internet. WPA/WPA2 wireless encryption keeps your wireless network secure and your traffic safe, allowing you to securely share your 4G LTE or 3G connections without worrying about unauthorised users accessing your network.
Easy to Set Up and Use
The DWR-921 4G LTE Router can be installed quickly and easily almost anywhere. This router is great for any situations where a wireless network is needed, or wherever conventional Internet access is unavailable. The DWR-921 can even be installed in buses, trains, or boats, allowing passengers to check e-mail or chat online while commuting or travelling.
Connectivity:
  • 4G LTE or 3G wireless WAN
  • Ethernet WAN port for fixed line xDSL/FTTH/cable broadband Internet
  • Four 10/100 Ethernet LAN ports to connect wired devices
  • Wireless 802.11 b/g/n
  • 802.3
  • 802.3u
Security Features:
  • WPA/WPA2 encryption to secure your wireless traffic
  • 64/128-bit WEP to secure your wireless traffic
Firewall:
  • Network Address Translation (NAT)
  • Stateful Packet Inspection (SPI)
  • Fast mobile Internet
  • Secure wired and wireless connections
    The DWR-921 utilizes dual-active firewalls (SPI and NAT) to prevent potential unwanted intrusions from Internet. WPA/WPA2 wireless encryption keeps your wireless network secure and your traffic safe, allowing you to securely share your 4G LTE or 3G connections without worrying about unauthorized users accessing your network.
  • Easy to set up and use
    The DWR-921 4G LTE Router can be installed quickly and easily almost anywhere.This router is great for any situations where a wireless network is needed, or wherever conventional Internet access is unavailable. The DWR-921 can even be installed in buses, trains, or boats, allowing passengers to check e-mail or chat online while commuting or traveling.
D-Link DWR-921 4G LTE Router - wireless router - WWAN - Wi-Fi - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
UMTS, HSDPA, HSUPA, LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
NAT support, Stateful Packet Inspection (SPI), VPN passthrough, IPSec passthrough
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
19 cm x 11.15 cm x 2.35 cm
0.5 kg
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, L2TP, IPSec
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Status Indicators
WLAN, WAN, LAN, 3G, SMS
Communications
Wireless cellular modem
Max Transfer Rate
100 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
19 cm
11.15 cm
2.35 cm
0.5 kg
10 - 90% (non-condensing)
9662 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9662 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.93
9662 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.58
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11g
Speed: 150Mbps
Brand: D-Link
