D-Link DWM-222 Wireless Cellular Modem 4G LTE USB 2.0 150 Mbps
Quicklinx: CQH1WS00 Mfr#: DWM-222
Type: Wireless cellular modem
Enclosure: External
Interface: USB
Compatibility: PC, Mac
£62.82 ex VAT
£75.38 inc VAT
The DWM-222 4G LTE USB Adapter is a portable travel modem that allows you to connect to the Internet wherever you are. With fast downlink and uplink data rates, as well as low latency, it provides you with a high-performance and responsive connection when you're on the road.
D-Link DWM-222 - wireless cellular modem - 4G LTE
Wireless cellular modem - USB 2.0
External
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSDPA, WCDMA, HSUPA, HSPA, LTE, DC-HSPA+
Apple MacOS X 10.5 or later, Microsoft Windows XP / Vista / 7 / 8 / 10
10.3 cm x 3.4 cm x 1.15 cm
33 g
1.13 W/kg (head) , 1.13 W/kg (body) , 1.13 W/kg (limb)
P/N: DSL-X1852E/NZ
External
Modem
Bus
USB 2.0
Wireless
Max Transfer Rate
150 Mbps
Antenna
Internal
Antenna Qty
1
Supported Flash Memory Cards
microSD, microSDHC
SIM Card Supported
Regular (mini-SIM) x 1
WHQL, RoHS
10.3 cm
3.4 cm
1.15 cm
33 g
P/N: DSL-X1852E/NZ
Enclosure: External
Interface: USB
Compatibility: PC
Compatibility: Mac
Brand: D-Link
