D-Link DWA-582 Wireless AC1200 DualBand PCIe Adapter
Quicklinx: B8C3WS00 Mfr#: DWA-582
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11b, IEEE 802.11a, IEEE 802.11n + 1 more
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
  • Wi-Fi CERTIFIED
  • IEEE 802.11n
13 In Stock
£18.48 ex VAT
£22.17 inc VAT
The DWA-582 Wireless AC1200 Dual-Band PCI Express Adapter connects your computer to a high-speed network and provides a blazing-fast Wireless AC connection with superior reception. Once connected, you can access your network's high-speed Internet connection while also getting secure access to shared photos, files, music, video, printers and storage.
  • Upgrade to wireless AC performance
    By upgrading your laptop and desktop computers to AC, you can immediately enjoy the benefits of faster wireless speeds and better connectivity - all with less wireless interference so you can enjoy doing what you love most. Delivering Wi-Fi dual band speeds to your laptop or desktop computer, the DWA-182 is the perfect solution for those looking to enjoy online gaming, smooth HD video streaming, fast file transfers and lag-free video chatting.
  • Backward compatibility
    While the Wireless AC1200 Dual Band USB Adapter delivers blazing fast AC speed to your laptop or desktop computer, it's also backward compatible with older Wi-Fi routers and devices - no updates or adapters necessary.
  • Easy push button setup
    Quickly and easily establish a fast, secure home network that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
D-Link Wireless AC1200 DWA-582 - network adapter - PCIe
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Bus Voltage
3.3 V
2.5 cm x 12.1 cm x 7.9 cm
48.8 g
Wi-Fi 5
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Network adapter
PCI Express x1
Bus Voltage
3.3 V
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
WMM support, QoS, WPS
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
4.5 dBi
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
C-Tick, IC, FCC, NCC
Software Included
Drivers & Utilities
2.5 cm
12.1 cm
7.9 cm
48.8 g
0 - 90% (non-condensing)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: D-Link
