The AC1900 Ultra Wi-Fi USB Adapter lets you upgrade your desktop or laptop to the latest generation wireless AC speeds, so you can easily stream HD media, download music, and enjoy high-speed online gaming.
The AC1900 Ultra Wi-Fi USB Adapter lets you upgrade your desktop or laptop to the latest generation wireless AC speeds, so you can easily stream HD media, download music, and enjoy high-speed online gaming. -
More speeds for PCs and Macs
The DWA-192 is powered with a 3 x 3 antenna design supporting speeds of up to 600 Mbps on the 2.4 GHz and 1300 Mbps on the 5 GHz to deliver fast wireless speeds and less interference for maximum throughput. It is the perfect match for your high performance router. -
Do more with Dual-Band
Use the 2.4 GHz Band for everyday takes such as surfing the web or chatting online while leaving the high-speed 5GHz AC Band free for video streaming, online gaming and large file transfers. -
Advanced AC SmartBeam technology
Improves coverage by directing bandwidth to your devices as you move around your home. You can stream HD video, surf the web, skype your friends and play online games from wherever you are so you will always get the best experience. -
High powered amplifiers
Want some wall penetrating Wi-Fi performance with three times the range of standard Wi-Fi adapters? The DWA-192 will extend the signal to your router. -
USB 3.0
SuperSpeed transfer mode will let you transfer data 10x faster than USB 2.0 standard. Get increased performance and better power management. -
Made for larger homes
Have a home with lots of devices and rooms? Using the latest AC technology, this adapter will give you better wireless coverage and better speeds so that you are connected in more places. -
Unique design
With its cool looking design, the DWA-192 is the only AC1900 USB adapter that comes with a design that will get everyone's attention. -
Works with all routers
Worried about the DWA-192 not working with your older router and range extender? The DWA-192 is compatible with all brands of Wi-Fi routers and range extenders.
- D-Link DWA-192 - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 7.992 cm x 7.992 cm x 7.7 cm
- 167 g
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- System Requirements
- Microsoft Windows 7 / 8 / 8.1
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Status
- WPS, on/off switches
Aerial
- Antenna
- Internal
- Encryption Algorithm
- WPA, WPA2
- RoHS, RCM
- OS Required
- 7.992 cm
- 7.992 cm
- 7.7 cm
- 167 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
