This USB Adapter enables you to transform your wireless Internet connection by using Wireless AC Technology, the fastest wireless technology available today. You can download web content and synch files to a mobile device up to 4 times faster* than the previous standard, and have extended coverage around your home with fewer wireless deadspots. Get revolutionary wireless speeds which allow you to check your email and surf the Internet or game, make Skype™ calls and stream HD movies to multiple devices using the interference-free 5GHz band.
The latest in wireless, 802.11ac Technology, brings you the fastest speeds, extended coverage around the home and fewer wireless deadspots. Get revolutionary wireless speeds for flawless HD video streaming to multiple devices.. Dramatically improve the wireless coverage in your home, allowing you to watch HD-quality video from more devices, in more places, simultaneously.
Compatible with all your wireless products
While the Wireless AC Dualband Adapter delivers cutting-edge 802.11ac speed to your home network, it's also backward compatible with all of your current wireless products - no updates necessary.
Easy WPS push button setup
Quickly and easily establish a fast, secure Internet connection that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
*When compared with Wireless N 300
Interference-free bandwidth
The wireless AC1200 Dual Band USB adapter (DWA-182) delivers Dual Band technology to your home network for intelligent, versatile, interference-free bandwidth. Check your email and surf the Internet on the 2.4GHz band; or game, make Skype calls and stream HD movies to multiple devices using the cleaner, interference-free 5 GHz band. Whatever you like to do online, Dual Band has you covered. -
Quickly and easily establish a fast, secure home network that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
- D-Link Wireless AC1200 DWA-182 - network adapter
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 9.73 cm x 2.91 cm x 1.35 cm
- 20.5 g
- Data Link Protocol
- 802.11a, 802.11b/g/n, 802.11ac (draft 2.0)
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP3
- Microsoft Certification
- Compatible with Windows 7
- 1 year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Active
- Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC Class B certified, IC
- OS Required
- 9.73 cm
- 2.91 cm
- 1.35 cm
- 20.5 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
