D-Link DWA-182 Wireless AC Dualband Adaptor
Quicklinx: 8QSSWS00 Mfr#: DWA-182
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11a, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£24.14 ex VAT
£28.96 inc VAT
This USB Adapter enables you to transform your wireless Internet connection by using Wireless AC Technology, the fastest wireless technology available today. You can download web content and synch files to a mobile device up to 4 times faster* than the previous standard, and have extended coverage around your home with fewer wireless deadspots. Get revolutionary wireless speeds which allow you to check your email and surf the Internet or game, make Skype™ calls and stream HD movies to multiple devices using the interference-free 5GHz band.
The latest in wireless, 802.11ac Technology, brings you the fastest speeds, extended coverage around the home and fewer wireless deadspots. Get revolutionary wireless speeds for flawless HD video streaming to multiple devices.. Dramatically improve the wireless coverage in your home, allowing you to watch HD-quality video from more devices, in more places, simultaneously.
Compatible with all your wireless products
While the Wireless AC Dualband Adapter delivers cutting-edge 802.11ac speed to your home network, it's also backward compatible with all of your current wireless products - no updates necessary.
Easy WPS push button setup
Quickly and easily establish a fast, secure Internet connection that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
*When compared with Wireless N 300
  • Interference-free bandwidth
    The wireless AC1200 Dual Band USB adapter (DWA-182) delivers Dual Band technology to your home network for intelligent, versatile, interference-free bandwidth. Check your email and surf the Internet on the 2.4GHz band; or game, make Skype calls and stream HD movies to multiple devices using the cleaner, interference-free 5 GHz band. Whatever you like to do online, Dual Band has you covered.
  • Easy WPS push button setup
    Quickly and easily establish a fast, secure home network that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
D-Link Wireless AC1200 DWA-182 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
9.73 cm x 2.91 cm x 1.35 cm
20.5 g
802.11a, 802.11b/g/n, Wi-Fi 5
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Microsoft Windows 7, Microsoft Windows XP SP3
Microsoft Certification
Compatible with Windows 7
1-year warranty
Network adapter
External
USB 2.0
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Active
WPS
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC Class B certified, IC
9.73 cm
2.91 cm
1.35 cm
20.5 g
Limited warranty - 1 year
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac (draft 2.0)
Compatibility: PC
Brand: D-Link
