D-Link DWA-172 Wireless AC600 Dual-Band High-Gain USB Adaptor
Quicklinx: B8GLWS00 Mfr#: DWA-172
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£18.29 ex VAT
£21.94 inc VAT
The DWA-172 Wireless AC600 Dual-Band High-Gain USB Adapter lets you experience faster wireless speeds than ever before by delivering powerful Wireless AC technology to your desktop or notebook computer. Simply plug the adapter into an available USB port and connect to a secure wireless network with an Internet connection, and right away you'll be browsing the web, chatting to your friends, streaming HD video or gaming online.
  • Compatible with all your wireless products
    While the DWA-172 wireless AC600 dual-band high-gain USB adapter delivers cutting edge 8D2.11ac speed to your home network, Its also backward compatible withal of your current wireless products. Tired of buying a new device only to find that you need to upgrade everything else? Just connect the DWA-172 to your existing hardware, connect to the Internet, and start browsing; saving you both time and money.
  • Portable design
    Whether you're at home using a desktop computer or out and about with a notebook, the DWA-172 wireless AC600 dual-band high-gain USB adapter's sleek design is perfect for mobility and convenience, so that you can take advantage of Wireless ACS super-fast speed wherever you are.
  • Reliable bandwidth
    The DWA-172 wireless AC600 dual-band high-gain USB adapter uses dual- band technology for intelligent, versatile, low-interference bandwidth. Check your email and surf the Internet on the 2 A GHz band; play online games, make calls over the Internet, and stream HD movies to multiple devices using the cleaner, low-interference 5 GHz band. Whatever you like to do online, dial-band technology has you covered.
  • Easy, hassle-free setup
    Use Wireless Protected Setup (WPS) to quickly and easily establish a highly secure home network that will have you browsing, streaming, and Interacting In minutes The latest encryption technology ensures that Information transmitted on your network remains safe and secure, while preventing unauthorized access. It's as easy as push and connects!
D-Link Wireless AC600 DWA-172 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
19.3 cm x 1.57 cm x 1.5 cm
23.2 g
Wi-Fi 5
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
WPS
Aerial
Antenna
External integrated
Gain Level
3 dBi
Encryption Algorithm
WPA, WPA2
FCC Class B certified, C-Tick, IC
19.3 cm
1.57 cm
1.5 cm
23.2 g
10 - 90% (non-condensing)
B8GL C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: D-Link
